Removal of my MSD ignition, back to OEM... do I have to change something in my EMS ?
Old Jun 2, 2006 | 04:59 AM
yellowturbo's Avatar
Default Removal of my MSD ignition, back to OEM... do I have to change something in my EMS ?
Ok I have this stupid problem that I never had before since I installed my new turbo...
The problem is : If I just accelerate smoothly and get some boost ( like 5-6 psi ) and im not full throttle the car have some misfiring issues at precisely 3800-4000 and if im past this range and I floor the car or go mid-throttle to accelarate the car is super fine ! So I cant enjoy the benefit of my GT28RS...
Also some people say that ACCEL wire are ****... so I will get some new OEM plug wires... a new ignitor and a new rotor on the car tonight but I also want to remove all my MSD stuff since I dont really need it ? It will just be easier later if I have a trouble. I will also check all my grounds.
So if I remove all the MSD stuff and put my OEM coil back in the dizzy do I have to reprogram something in my AEM EMS ??? I dont know anything about that...
Also someone told me that it might be the vibration of the dizzy shaft/bearing that might be my trouble ?? What do you think about that ??
After that I will raise the boost to 20 psi that might be fun.
Thanks for the help !
Mat
Old Jun 2, 2006 | 06:20 AM
mrbsponge's Avatar
hmm, thats 2 this week, i just took mine off too.
i was having misfire problems at 7000 no matter what i did, took it off and the car runs so much better. DO IT
you dont have to change anything in the EMS, you may wanna gap your plugs down a tad just in case, but you dont need to input any new values then what you had before
Old Jun 2, 2006 | 07:13 AM
Peter Shen's Avatar
Default Re: (mrbsponge)
yeah i had a random misfiring problem above 6000rpm that wouldn't go away no matter what we did or tried.. then we got rid of the stupid MSD 6A box and everything was fine after that
Old Jun 2, 2006 | 07:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">hmm, thats 2 this week, i just took mine off too.
you dont have to change anything in the EMS, you may wanna gap your plugs down a tad just in case, but you dont need to input any new values then what you had before</TD></TR></TABLE>
well im sure that its NOT the MSD because I removed the SCI box and it doesnt change anything... the coil is brand new.
Tony1 told me that I will need to change something in the coil dwell or something like that. I may try it without any change but I dont want to fry my OEM coil lol
Old Jun 2, 2006 | 08:49 AM
Civic TSI's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">
No problem, I got some in stock I'll try to remove it too tonight, all I have to do is disconnect the 2 wires from the 6AL and wire them to the external coil. 50% chance of not wiring them correclty
Old Jun 2, 2006 | 08:55 AM
D-tuned's Avatar
Default Re: (Civic TSI)
you have to change the coil dwell. just use the coil dwell wizard
Old Jun 2, 2006 | 09:07 AM
Default Re: (D-tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-tuned &raquo;</TD></TR><TR><TD CLASS="quote">you have to change the coil dwell. just use the coil dwell wizard</TD></TR></TABLE>
thanks just look at your pm !
Civic TSI : lol yeah I know what you mean.... I will figure this out tonight. I just got my igniter, rotor and new plug wires at Honda.
Looks like I have some work tonight.
Old Jun 2, 2006 | 09:57 AM
Civic TSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-tuned &raquo;</TD></TR><TR><TD CLASS="quote">you have to change the coil dwell. just use the coil dwell wizard</TD></TR></TABLE>I was wondering what the hell you were talking about until I realized that this is specific to the EMS. I run a chipped P28.
Old Jun 5, 2006 | 04:48 AM
soooo finally I changed all my MSD stuff for the stock ignition, coil, distributor cap, new igniter, new OEM wires and it STILL do the same problem....
I begin to be sure that its a tuning problem because its always in the same range. Its around 4000rpm were my GT28RS is supposed to kick in so I assume that my tuner didnt set the map correctly....
Who could take a look at my map just to tell me if there is something wrong....
Thanks
Mat
Old Jun 5, 2006 | 06:50 AM
Civic TSI's Avatar
Thanks
Mat </TD></TR></TABLE>
Want a slap in the face or what ?
Old Jun 5, 2006 | 07:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">
Want a slap in the face or what ? </TD></TR></TABLE>
Ca veut tu dire que tu veux la regarder lol ? Samedi il mouillait donc...
Old Jun 5, 2006 | 08:33 AM
notoriousB's Avatar
sent you PM re: AEM misfires.
Old Jun 5, 2006 | 08:41 AM
Mase's Avatar
nah thats wrong, you should change the dwell settings.
Old Jun 5, 2006 | 09:14 AM
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
yeah I did that too ! It was pretty easy....
EJ8Squad919
Jun 16, 2012 11:41 AM
StreetRac3r
Jun 11, 2007 08:36 PM
EE_Chris
Apr 28, 2005 12:16 PM
mr.beeks
Jul 30, 2003 07:14 AM
Screamer
Apr 6, 2003 08:30 AM
