SRS light is on.
Old Jun 2, 2006 | 04:54 AM
mjej's Avatar
Default SRS light is on.
I left my lights on all night and my battery was dead. So I got a friend to jump me and I was on my way. Only thing is that the SRS light is stuck on any clue why it is? Or how I can turn it off? Thanks.
Old Jun 2, 2006 | 06:14 AM
JamesV's Avatar
Default Re: SRS light is on. (mjej)
d/c the battery and reconnect :-\ i dont know really know but its worth a shot
Old Jun 2, 2006 | 06:40 AM
gabebauman's Avatar
Default Re: SRS light is on. (JamesVista)
Remove the bulb in the gauge cluster.
Old Jun 2, 2006 | 07:10 AM
mjej's Avatar
haha! I'm trying to do it the legit way lol.
Old Jun 2, 2006 | 07:18 AM
gabebauman's Avatar
Default Re: (mjej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjej &raquo;</TD></TR><TR><TD CLASS="quote">haha! I'm trying to do it the legit way lol.</TD></TR></TABLE>
Cool...I removed my bulb because I have an aftermarket steering wheel...so I have no airbags. Sorry I can't help.
Old Jun 2, 2006 | 07:25 AM
mjej's Avatar
Default Re: (gabebauman)
looks like I might have to remove the bulb. I'll try to reset the battery first if that doesn't work who knows I might remove the bulb.
I read other forums saying means srs failed and all this crap and it's 500-800$ to fix screw a bunch of that for a 10 year old car.
Old Jun 2, 2006 | 07:36 AM
mrehagencivic's Avatar
i had an airbag light when i pulled my airbag off, and then turned the ignition on, the computer senses sometings wrong and then the airbags will not deploy like there supposed to. i did a manual reset of the airbag circuitwhich required a jumper wire and too people, i found the information on ALLDATA , yes, yes i know this program almost never has the right info, but it did for this and it worked, i would explain how to do it put i can't find the paperwork that i printed off to do it
if you know someone who works at an automotive shop they "should" have access to information like this
good luck
Old Jun 2, 2006 | 08:08 AM
JamesV's Avatar
Default Re: SRS light is on. (mrehagencivic)
how do you take the bulb out?
i tried it just now and only found two screws but the thing wont come off :-\
Old Jun 2, 2006 | 09:55 AM
mjej's Avatar
agreed on removing the light?
Old Jun 2, 2006 | 10:02 AM
B16CivicEX's Avatar
look in the arcive, there is a few for gauge removal,
Old Jun 2, 2006 | 10:49 AM
gabebauman's Avatar
Default Re: (AirForceB16)
I know on my 98 ex cluster and 98 teg ls cluster...the bulbs have a black tab that you just twist and remove the light.
Old Jun 2, 2006 | 11:57 AM
mugenhatchie's Avatar
I know on civics 96+ there was a factory recall for that happening. I had the same problem on my 4 door. Eventually I just replace the factory one with a sparco wheel and said screw the light
Old Jun 2, 2006 | 12:09 PM
coupEJunkie's Avatar
Default Re: SRS light is on. (mugenhatchie)
My 97 dx does has that idiot light on too...what a piece. I just thought it was the swap or something.
Old Jun 2, 2006 | 02:00 PM
Del Sizzle's Avatar
This happen to me before in my del sol. I disconnected the battery for a couple of hours but the light stayed on. As long as the light is on, the airbags are disabled and will not activate in an accident. My solution was me going to the dealer and paying a hours worth of labor ($76) for the to turn if off.
Civic-Kids
Oct 2, 2009 03:08 PM
whitehf
Sep 15, 2006 10:03 AM
lsvsol
May 18, 2006 08:14 PM
Slava.
10
Apr 29, 2006 07:33 PM
rscawley
Mar 5, 2004 05:39 PM
