Electrical Problems
Old Jun 1, 2006 | 05:56 PM
baPES's Avatar
Default Electrical Problems
Ok well i was driving my car andd when i almost got ot my detination i hear this noise. It would do it randomly annd when the noise started my tach would flicker. So i drove i to my destination and turn it of. Then i go to turn car on and i see smoke and it flickers again and then stop doing it so i drive a litle more. Next time i get in my car abot 20 min later i trn car on and it suddenly dies on me and see smoke. After that car wont start/crank just does the beeping noise af if key wasnt in the on possition and none on the lights come on( the ones that turn on when u put it on on). And my alram also dosnt work? Any suggestions?
thanks
Old Jun 1, 2006 | 06:13 PM
baPES's Avatar
Default Re: Electrical Problems (baPES)
car dosnt click or anyhting seems like the car dosnt know its on the on position.
Old Jun 1, 2006 | 06:20 PM
eg6ajk's Avatar
smoke from where?
whats the voltage at the battery? alternator plug and wiring ?
my money is on the alternator getting fried and possibly blowing some fuses. check the connections and fuses.
check the manual:
http://carfiche.com/manuals020/cars/
Old Jun 1, 2006 | 06:55 PM
baPES's Avatar
Default Re: Electrical Problems (eg6ajk)
thanks ill be checkign thoose
Old Jun 1, 2006 | 06:56 PM
baPES's Avatar
Just came from under dash or even maybe from sterirng wheel not to sure
Old Jun 1, 2006 | 07:06 PM
sicegcivic's Avatar
who installed the alarm? if it isnt alternator (or anything else under the hood) then i would start there. also is there anything else wired into the car that isnt factory?
Old Jun 1, 2006 | 07:11 PM
baPES's Avatar
Default Re: (sicegcivic)
Nope would the alternator caause alarm not to work or would it caus the car not knowing key is turned?
Old Jun 1, 2006 | 07:20 PM
sicegcivic's Avatar
Default Re: (baPES)
a bad alternator would cause a dead battery which would in turn cause alarm not to work. but smoke from under the dash/steering column sounds like something is shorting out. i would check if there are any burnt or melted wires, and check any wires that look tapped into.
CivicHP
Mar 15, 2005 12:04 PM
IntegraFroggie
Jun 24, 2004 05:49 PM
Ya@inlinePRO
Aug 6, 2003 12:22 PM
UnionCity LS
Feb 5, 2003 07:49 PM
