Whats the best motor swap...B20 or jdm B16A obd-1
Old Jun 1, 2006 | 02:24 PM
nolimitlowrider's Avatar
Default Whats the best motor swap...B20 or jdm B16A obd-1
I have a 92 si and have a choice of a 2001 B20 or a JDM obd-1 B16A. Which one would be best in the si, and most powerful? Thanks
Old Jun 1, 2006 | 02:26 PM
JDM-EJ1's Avatar
Default Re: Whats the best motor swap...B20 or jdm B16A obd-1 (nolimitlowrider)
Why do you only have a choice of those motors? I would either get an H22a, B18c, or any K20/24 motor.
Old Jun 1, 2006 | 02:33 PM
EK79's Avatar
Default Re: Whats the best motor swap...B20 or jdm B16A obd-1 (JDM-EJ1)
why dont you do a pro and con between the two and pick which would be better for "YOU" if you ask us "WE" will tell you what "WE" think and youwill base your choice on our decisions make your own choices ............but if i had to choose i would go with the B16A JDM ................com to think of it I HAVE ONE ALREADY.
Old Jun 1, 2006 | 02:37 PM
littlegreenb18's Avatar
it depends on what you plan to do with it, if its going to remain stock, i'd go with the higher output, which would be the b16
Old Jun 1, 2006 | 02:46 PM
JDM Vision's Avatar
350 small block
Old Jun 1, 2006 | 02:58 PM
Formula's Avatar
"F" that, 425 BIG BLOCK!!!!! lol.
No, but seriously I would go with the JDM B16A if you want a nice, simple, and respectable car. Also if your car is a SI then you should already have VTEC which means you don't have to wire the B16A for VTEC. If you plan on going boost or a built NA engine then the B20 should be a cheaper engine to buy which would save you some $$$ when you build or boost the engine.
Modified by Formula94 at 4:15 PM 6/1/2006
Old Jun 1, 2006 | 07:06 PM
Default Re: Whats the best motor swap...B20 or jdm B16A obd-1 (stoopid monkey)
Thanks... Well i have both motors in my hands. The b20 is already in my si, and i bought the b16 before i bought the car, and have never driven a b16 so not sure of its power. The b20 has alot of bottom end power thought, don't really wont to do the crvtec because i heard that the bottom end would not hold up very long, if it was not built. So i just wanted to hear of people that own b20 and b16. I am getting my p30 ecu chipped here soon, because its from an auto. Thanks for all the help.
Old Jun 1, 2006 | 07:08 PM
JDMlyfestyle's Avatar
Well since this gets asked almost daily, me and BauleyCivic have decided that making a thread to showcase, if you will, the swaps.
Some intro swap information
Switching OBD motors
Many people think that swapping in a pre OBDI motor into their 92+ Civic is a good idea. I disagree. First, you'll have to swap the car from OBDI to OBD0 ot try and change the motor to OBDI. If you get a swap older than a 1991, you have to deal with the cable to hydro tranny conversion. The 1992-1993 Integra is the oddball swap of the bunch, being OBD1 and cable tranny. Your stock Civic has a hydraulic transmission.
Swapping from OBDII to OBDI is a common thing more and more now. Although the idea is quite good, it has flaws. If you use a jumper harness, it is very difficult to get the ECM to fit back in it's original location. Also, unless you feel like changing things back at inspection time, it's going to be impossible to pass in some areas. Now places are implementing OBDII testing that will have the tester plug a computer into your OBDII port to check for legality (no pulling the check engine light bulbs anymore to pass).
General swap info and tips
This could be better covered by someone with more swap experience, but I'll put in my $.02. Do it from the top. Just because more people have access to the tools and locations where putting in a swap from the top is easier. Also, make sure you have some way to crack the axle nuts loose. Air tools are a lifesaver when you have to turn bolts in a job like this, as is a torque wrench and a GOOD set of sockets.
If you can follow directions on here and unbolt things and rebolt them with a little wiring, you can do a swap.
A special thanks goes out to JDMlyfestyle for this thread https://honda-tech.com/zerothread?id=983454
JDM Swaps
Honestly, unless these come from a friend in Japan, you're taking a gamble every time. You have no real way to know how many miles are on the engine, nor how it was treated. Just keep that in mind. It has not been proven (no matter how many claims) that these JDM motors make any more HP.
Where to find them
First of all, if you are looking for a USDM motor, I'll suggest local junkyards. They are probally your best bet, as you can look at what you're getting instead of having to order it. Many people on here have bough swaps online, and they have posted their experiences in this thread:
https://honda-tech.com/zerothread?id=50010
Possible Swaps
Now before someone jumps on me and says anything is possible with enough time and money, I know. These are going to be fairly straightforward options with the pros/cons.
D series swaps
These are fairly inexpensive and come in a variety of Civics. IMHO, these are the easiest swaps to drop in. I also don't want to hear a bunch of whining about the opinions on power levels. Of course there are going to be some exceptions to the rule.
Pros
Inexpensive
Decent potential (200 whp or so on stock internals)
OEM parts are cheap
More than enough for most people
The best D series come with ~130 hp tops
Optional factory LSD in the JDM D15B
Cons
Not as much potential as some other motors
Transmission not geared for accelleration
Don't respond to bolt ons well
Only way to get real power out of them is FI
B16
These can be found in the JDM SIR and SIRII (among other JDM cars, which I don't claim to know all of which it came in) as well as the USDM 99-00 SI (EM1) and the 99-00 Canadian SIR.
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
113ft/lbs torque (very little more than a D16z6 stock)
Without knowing what you're looking for you can end up with a high mileage JDM model
Under 4k or so it feels just like a D16
B18B
This is the motor in the non Type-R and non GSR Integra.
Pros
Good torque for a 1.8L (127 ft/lbs)
Inexpensive (even cheaper than a B16)
142 hp (more than any stock D series)
Boost heads love them
Cons
No VTEC
Longest B series transmission
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
B18C5 (or JDM B18C)
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
B16B
This is the motor found in the Civic Type R found all over the world.
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
Expensive- almost as much as an ITR for lower performance
Very little torque still, have to rev the motor to make power
B20
Pros
Great torque (133 ft/lbs)
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
Have to peice together a swap for a Civic (can't drop it in with a B20 tranny)
Won't pass BAR (light truck motor in a car)
Low hp in the B20b(126 hp)
H22/JDM F20B
Pros
200 hp
H22=156 ft/lbs torque
F20B=145 ft/lbs torque
Great torque
DONT WEIGH THAT MUCH MORE THAN A B SWAP!!
https://honda-tech.com/zerothread?id=684550
Cons
Harder to install than a B/D motor
transmission feel is vague IMHO
Less info out there for the swap (aka, less experience as they are less common)
Price of swap is comperable to a B18C5 after everything is said and done (mounts, etc)
K20
This can be found in the new EP3, the RSX (base and Type S) as well as other cars across the world (RSX R, etc). This is the future of the swap IMHO. There is a writeup on installing one of these in one issue of Sport Compact Car magazine (June 2004 I *think*)
Pros
200 hp 158 ft/lbs torque (RSX R)
I-VTEC
Respond VERY well to bolt ons
6 speed transmission
Most have very low miles
Cons
Still super expensive
More difficult swap than a B or D
Well, there you have it people. I've outlined some of the pros cons on some of the most popular swaps.
Check out the FAQ thread for more info on how to install them.
https://honda-tech.com/zerothread?id=642479
Most of these HP/TQ numbers were taken from Hmotors online if I didn't know them. Don't bite my head off if they aern't correct. I don't claim to be a walking encyclopedia, so I have had some help.
Old Jun 4, 2006 | 06:31 PM
Old Jun 4, 2006 | 09:23 PM
SiRek4
Guest
Posts: n/a
b16a is a strong motor and the rod ratio is amazing.
i think thats the best b series motor ever made minus the type r.
but if you really have bucks, get a k20r.
thats where its at!!!
Old Jun 5, 2006 | 11:08 AM
Default Re: Whats the best motor swap...B20 or jdm B16A obd-1 (SiRek4)
Thanks.. I am going to put in the b16a and see how it does. I may just do the crvtec later on. But most people say the botton end will need to be built. Is that true or will the b20z bottom end be good to go?? Thanks all!
Old Jun 6, 2006 | 11:22 AM
SiRek4
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolimitlowrider &raquo;</TD></TR><TR><TD CLASS="quote">Thanks.. I am going to put in the b16a and see how it does. I may just do the crvtec later on. But most people say the botton end will need to be built. Is that true or will the b20z bottom end be good to go?? Thanks all!</TD></TR></TABLE>
smart choice
ive had both in my crx (b20vtec & b16a) and No, you dont have to have the bottom end built, but its alot better, seeing is how the compression on a b20 is really low.
although i will say, i was much more happier with the 1.6, it revved better, my tires would hook better, and it took a beating.
you can use the b16 to daily drive, go to the track (streets of willow), or just drive around at night and crack vtec.
Old Jun 8, 2006 | 10:01 AM
iamalex1212
Feb 23, 2009 06:49 PM
1994delsolLS
Sep 10, 2008 06:15 PM
crazyguy
Aug 9, 2007 05:40 AM
nolimitlowrider
May 31, 2006 01:08 AM
ef9robert
May 4, 2006 07:49 AM
