Help I need a new ECU, I think???
Old Jun 1, 2006 | 01:20 PM
khmoe's Avatar
Default Help I need a new ECU, I think???
I have a 95' hatch with a JDM B18C.
I have a problem: it is running too rich. de CO level is good at idle, but it gets too high when testet at higher RPM. The car runns like ****, it fires in the exhaust when i shift at 4-5000rpm, and it strugles to get to the redline. My apexi RSM shows the car has like 70-100hp and not 200-230hp as before This **** started suddenly, when driving it in the city.
There is no CEL code.
I have tried this:
New Fulefilter
new Sparkpluggs
new Dizzy
New Map sensor
Help me I'm so frustrated right now
Thanx for any reply
JDM B18C
JDM P73 OBD2a
Thnx
Kristian Moe
Larvik, NORWAY
Old Jun 1, 2006 | 03:14 PM
sp00nek9's Avatar
compression check?
Old Jun 2, 2006 | 12:25 AM
khmoe's Avatar
Default Re: (sp00nek9)
it works well up until 5000rpm, but it can fire in the exhaust when i shift, but other than that the car has less power. But it is good to drive below 5000rpm/vtec.
So you think it could be compresion, i have mild down the head and changed headgasket. last year.
Old Jun 2, 2006 | 05:22 PM
Girlzcn2's Avatar
i wouldnt say this is a ecu problem, usually when your ecu goes bad it throws a code. i would do a compression test but if it is a valve you would be down on power all the time not just a certain rpm's. could be your fuel pump?!?
Old Jun 6, 2006 | 03:52 PM
khmoe's Avatar
Default Re: (Girlzcn2)
compression is from 210 to 220 psi on all cylinders.
Other's that have any tips for me to try out??
Old Jun 10, 2006 | 01:02 AM
khmoe's Avatar
Default Re: (khmoe)
TTT
HELP MED PLEASE
Old Jun 10, 2006 | 02:11 PM
v4lu3s's Avatar
RTFM
i would try a stock p72 ecu to see if that will help.
Old Jun 11, 2006 | 10:01 AM
Mikey3000's Avatar
Default Re: (v4lu3s)
yeah do u have the ability to try out another ecu?
Old Jun 11, 2006 | 02:17 PM
khmoe's Avatar
Default Re: (Mikey3000)
I have a problem that every ECU has immobilizer in it, but soon i wil have my hands on a Hondata s300 and a harnes that will fit my car. OBD2a
Hope it will be easy to put inn a basemap and see if that helps.
A base map og b18c will run ok? or do i have to tune the basemap to test it on my car??
Hatch It
Engine Management and Tuning
May 25, 2014 11:43 AM
mac51o
Mar 1, 2011 11:18 AM
Snail Power
Oct 16, 2010 03:20 PM
khmoe
Jun 2, 2006 12:31 AM
khmoe
May 21, 2006 09:30 AM
