Car stuttering...any ideas??
Old Jun 1, 2006 | 12:36 PM
looxs's Avatar
Default Car stuttering...any ideas??
Hey wuts up, i have a b16a2 swapped eg and we took off the venom intake manifold and threw on a obd0 b16 intake manifold and now there's a CEL and the car stutters from 2-3.5K RPM. Is swapping manifolds non compatable or what?? Any help would be cool thanks.
Old Jun 1, 2006 | 12:44 PM
JDMlyfestyle's Avatar
ANY CEL?
Switch the Map sensor and the TPS plug see if that helps
Also check all grounds and be sure they are hooked up properly
Old Jun 1, 2006 | 12:55 PM
looxs's Avatar
Default Re: (JDMlyfestyle)
It is throwing a CEL but i'ts not one of those blinking ecu's and i dont have a computer diagnostic system. i havent checked the map sensor or TPS yet but i did take off the IACV and there was no coolant circulating through that. Could that be the problem?? and can you even use a obd0 intake manifold on a obd1 because of sensor placements?
Old Jun 1, 2006 | 01:52 PM
Here use my write up to help you figure out your CEL
https://honda-tech.com/zerothread/1171263
Old Jun 2, 2006 | 11:09 AM
looxs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Here use my write up to help you figure out your CEL
https://honda-tech.com/zerothread/1171263</TD></TR></TABLE>
Nice writeup and thanks for helping out.
iBrandon
Apr 16, 2007 05:52 PM
94gsrvtek19
Oct 5, 2005 02:51 PM
9hatchman4
Sep 12, 2005 03:15 PM
igo4bmx
Aug 31, 2005 10:50 AM
jdmrealm
Jan 31, 2002 12:33 AM
