ls/vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekVtecPower »</TD></TR><TR><TD CLASS="quote">how would u build them right? and what are the parts i should buy?</TD></TR></TABLE>
you cant do it
you cant do it
get some itr pistons, gsr oil and water pump, and some new bearings and rings then let a good shop assemble it and put it together. and tune asap. reson why people's ls vtec doesnt last is oil leaking problems. if its built right then it will last
like gold ef says, they'll only last long if you rebuild them right and perfect. if you dont build them right and perfectly, they wont last long. all it takes is time and money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef »</TD></TR><TR><TD CLASS="quote">you cant do it</TD></TR></TABLE>
Agreed. If you don't already know what goes into building that motor, then you should look into something else. They can be reliable if built correctly, but the biggest thing is rod stroke ratios and oil. There are a ton of write ups on the ls/vtec. Find one and learn.
Google
Buy the Omnipower video. Its great for the beginer engine builder.
Do your research and homework.
Build a powerhouse and come back and post the results !!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">get some itr pistons, gsr oil and water pump, and some new bearings and rings then let a good shop assemble it and put it together. and tune asap. reson why people's ls vtec doesnt last is oil leaking problems. if its built right then it will last</TD></TR></TABLE>
gsr main girdle
it's like a brace for the bottom end and will help keep the rotating assembly in check during upper rpm's
gsr main girdle
from what I've read (I've been trying to read up on the LS/VTEC until I found out that it prolly costs more than the GSR) u have to like, build it like blueprinted (if that's even possible on a 4 banger) -- think they said it has to be overhauled or u won't get much life out of it :-\
From: Dont You Just Love Lynn Cops, Boston MA, USMA
this shop i went to told me that the gsr main girdle doesnt nead to be machined, its basically a bolt on. Took it to a machine shop told me it neads to machined alittle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyz »</TD></TR><TR><TD CLASS="quote">this shop i went to told me that the gsr main girdle doesnt nead to be machined, its basically a bolt on. Took it to a machine shop told me it neads to machined alittle.</TD></TR></TABLE>
hmm...i thought it bolted right on too
camera obscura
18
May 26, 2003 03:56 PM
