D16a6 Camshaft in D15B7 , Searched already ...
Old Jun 1, 2006 | 09:52 AM
Royal_C!ty's Avatar
Default D16a6 Camshaft in D15B7 , Searched already ...
Hey guys first off searched already and i found a lot of helpful post from mistabone , timmay , etc. but i never really found a straight answer, so i'm looking to do this "cam swap" over the weekend and i'm wondering what all is needed for the camshaft to run properly what i mean by that is
1) i know you need a Y7/Y8 cam gear, can you use the oem one ? i see everyone talking about adj. cam gears but will the oem work ? ...
2) I also read up theirs a belt difference between the a6 and b7 (106 teeth compared to 107 teeth, if i remember correctly) so my question is do i have to go out and by the a6 belt or is the b7 belt fine ?
well if you guys could get back to me bring your flames on i'm ready ...
or you guys could just be helpful ...
thanks in advance
- Justin
Old Jun 1, 2006 | 11:46 AM
Royal_C!ty's Avatar
Default Re: D16a6 Camshaft in D15B7 , Searched already ... (eg8kid)
bump y0 !
mistabone , where are you ! ..
Old Jun 1, 2006 | 06:08 PM
Royal_C!ty's Avatar
bump y0 !
Old Jun 1, 2006 | 09:40 PM
Royal_C!ty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8kid &raquo;</TD></TR><TR><TD CLASS="quote">bump y0 !
mistabone , where are you ! .. </TD></TR></TABLE>
Old Jun 1, 2006 | 10:13 PM
Bense's Avatar
lol use the d16y7/y8 cam gear and the a6 cam and set your ignition timing.
there's no need to change the timing belts, d15 block is shorter than the d16 block, so it has a shorter timing belt
http://www.knology.net/~jediklc/pistonnotes.htm at the bottom
Old Jun 1, 2006 | 10:17 PM
Royal_C!ty's Avatar
Default Re: D16a6 Camshaft in D15B7 , Searched already ... (Bense)
Thank you ! ...
Needin_VTEC
Jan 12, 2013 12:43 PM
Sweetfish89
21
Sep 7, 2011 05:34 AM
flatblack-h22
12
Dec 28, 2006 05:23 PM
rass1313
Mar 14, 2005 11:20 AM
lst94
22
Feb 4, 2005 07:05 PM
