Running without resistor box??
Old Jun 1, 2006 | 08:10 AM
amadriga's Avatar
Default Running without resistor box??
I'm running my OBD0 B16A in my eg Civic SI without the injector resistor box, is there any problem running the engine this way? Should I get a resistor box, or can I find some OBD1 B16A injectors??
Thanks.
Old Jun 1, 2006 | 08:33 AM
1bar_ek's Avatar
Default Re: Running without resistor box?? (amadriga)
To my knowledge, if you're not running a resistor box, it will burn up the transistors that put out the pulses for the injectors to open, due to the fact that there are no resistors to limit the amount of current draw through them.
Old Jun 5, 2006 | 02:41 PM
amadriga's Avatar
Default Re: Running without resistor box?? (1bar_ek)
I have 2 years running it without resistor box, I think it could cause maybe a lean o rich mixture or affect milleage.
Cian Mcloughlin
Jul 29, 2013 04:52 PM
Vtec92Civic
Mar 17, 2004 10:02 PM
redboost10
Oct 23, 2003 03:35 PM
hondaZvic
Aug 27, 2002 09:39 PM
