3 questions
Old Jun 1, 2006 | 07:21 AM
lx130's Avatar
Default 3 questions
1. Does anyone know how to adjust the clutch pedal height, becuase my friction point is too close to the driver, makes it difficult.
2. Also, my brakes, everytime i slow down at a lightor a stop sign, and i apply constant pressure, the pedal starts to sink. i check the main cylinder and if there were any leaks, coulndt find any.
3. Any one know how to remove headlights and corner lights?
Old Jun 1, 2006 | 07:32 AM
crx_88_si's Avatar
2. leaking caliper or drum cylinder.
Old Jun 1, 2006 | 07:35 AM
65stang90crx's Avatar
Default Re: 3 questions (lx130)
1. What engine and tranny? Clutch cable or hydro? Is that for your truck or a CRX?
If its a CRX cable d15 like mine you adjust the clutch release point (looking at the engine from front) on the left side between engine and battery. There is an adjuster on the cable towards the end
2. Leak in brake line. Or MC is junk. (Prolly MC is junk)
3. ??? Never done it
Old Jun 1, 2006 | 07:39 AM
jlicrx's Avatar
Old Jun 1, 2006 | 07:52 AM
andrey320's Avatar
2. same problem I had - bad MC. if you are not loosing any fluid its a bad MC.
Old Jun 1, 2006 | 07:55 AM
Its me DUB's Avatar
CRX Repair Manual will answer these questions...... AND MORE.
Old Jun 2, 2006 | 06:33 AM
lx130's Avatar
Default Re: 3 questions (jlicrx)
do u know where the adjusting nut is located? i have a 1990 crx
Old Jun 2, 2006 | 06:36 AM
temp's Avatar
shop manual ftw
Old Jun 2, 2006 | 06:58 AM
thesmogman's Avatar
follow the cable towards the tranny, there is a mounting bracket down by the battery. You should see a nut on the cable pull up on the cable and give it a turn then try it. if more is needed repeat.
And it is your master cylinder, look just below it on the bottom of the brake booster.
Headlights I haven't done either.
Old Jun 2, 2006 | 07:03 AM
b18sihatch's Avatar
you could have a stretched cable, but if thats not the case and it just needs adjusting be carful not to make it too tight as you could stretch the cable
Old Jun 2, 2006 | 07:38 PM
lx130's Avatar
anyone know how to take out headlights?
Old Jun 3, 2006 | 08:28 AM
temp's Avatar
Default Re: (lx130)
http://hybrid.honda-perf.org/t...l.pdf
86si75
Classic Hondas
Sep 9, 2013 03:32 AM
mercury24
12
Aug 29, 2013 07:05 AM
JustaEgg
Transmission & Drivetrain
May 23, 2012 08:13 PM
DeadboltReX
Classic Hondas
Jan 3, 2012 03:04 PM
MarksIntegra
Dec 22, 2006 07:02 AM
