Tilton Twin disk cerametallic clutch w/ oem fly wheel
I used this clutch for less than 6000 miles, still grabs like a mug!! was on my 600 hp integra and doesn't slip at all. I purchased it from Stan @ fast-turbo.com it comes with machines oem fly wheel for easier drivability. Pm me for any questions.
Asking $875 or best offer!!
here is a small description.
Features:
- Tilton OT-II 7.25" Pressure plate
- Dual Twin Ceramettalic Disks
- All hardware such as heat shields, floater plate and etc.
- Lightened and Machined OEM flywheel
Advantage:
- Durable assembly
- Reliable and Proven setup
- Will be able to handle up t0 700 lb/ft of torque
- Comes assembled and tested.
Benefits:
- The last clutch set you will ever buy !!
- Will not outnumber your WHP (unless you're pushing over 700 lb'ft therefore you won't need another clutch when you make more WHP.
- Very Streetable with OEM Flywheel ~ 13lbs
- Solid yet smooth engagement
- Better time at the track with less slippage !!
Pic
Modified by TOP_END_Turbo_GSR at 9:38 AM 8/1/2006
Modified by TOP_END_Turbo_GSR at 6:50 PM 8/1/2006
Features:
Advantage:
- Durable assembly
Benefits:
Pic
chrisb
19
Oct 21, 2005 12:14 PM
