elbow deep into my d16b5 project and now I'm getting other issues
Okay, the clutch is now working fine, but whenever I start it up, and give it throttle it BOGS. Also, i'm getting now speedometer readings. I have checked the vss wires, and have swapped vss's, but still no mph
the only way that it will run is if it is idling. I was able to "idle" down the street at like 1100 rpms lol. but the second i give it gas, it bogs and wants to die.
I am running off of a gsr fuel map. I have also switched throttlebodys and took a tps sensor off of a vx throttlebody and put it on a 62mm throttlebody, but i made sure to put that thing in it's right "groove"
Any ideas on any of this anybody?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Sounds just like a TPS/MAP sensor confusion. Also, have you checked your TPS for the right voltage signal?</TD></TR></TABLE>
i'll try to swap the tps/map plugs right now
could it be your timing? Because there was a simiular thread and it turned out to be a timing issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Glad to help my friend
i still sometimes get the MAP and TPS switched around once in a while...glad to see someone else metions it. as for the VSS you have continuity betwen the sensor anf the ecu right, along with the cluster. check the voltage on the wires too...and then do a voltage drop test on the postive(s) AND ground side of the circut... might be a ground issue
hatchinprogress
Nov 23, 2004 08:21 PM
