Crazy speedo needle
Old May 31, 2006 | 04:48 PM
Darkseid's Avatar
Default Crazy speedo needle
I have a ek with a GSR the speedo needle just spins around. any suggestions.
Old May 31, 2006 | 06:36 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Crazy speedo needle (Darkseid)
check your terminals on your speed sensor and clip. you might have a bad speed sensor if they look fine.
Old May 31, 2006 | 09:08 PM
confusatron's Avatar
check the wire plug connection at the speedometer sensor. Mine did the same thing before it went out completely. You may have to redo the wire pins going into the plug. It's a real bitch.
lwmmuas
Jun 11, 2013 12:24 PM
FrontwheelENT
Jan 7, 2012 07:30 AM
LaEzEnT
Dec 15, 2008 07:50 PM
Silvabullet
Jan 5, 2005 02:06 AM
HATCHMO92
Aug 8, 2004 02:09 PM
