Neuspeed "L" bracket question.
Old May 30, 2006 | 08:06 PM
mkazm83's Avatar
Default Neuspeed "L" bracket question.
I have the Neuspeed rear swaybar which I got used with the car. It did not come with the Neuspeed "L" brackets nor was I aware that they were available so ive been driving around with the stock ones for over a year. My question is if its worth getting those Neuspeed brackets. Is it more of a security to have them or are they going to maximise the performance of the bar. I called Neuspeed today and they want $60 a peice.
Thanks.
Old May 30, 2006 | 08:22 PM
soundbomber's Avatar
Default Re: Neuspeed "L" bracket question. (mkazm83)
is this for the front or rear?
Old May 30, 2006 | 08:59 PM
mlh908's Avatar
Default Re: Neuspeed "L" bracket question. (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">I have the Neuspeed rear swaybar </TD></TR></TABLE>
Old May 30, 2006 | 09:00 PM
Default Re: Neuspeed "L" bracket question. (mlh908)
haha i'm retarded...
Old May 31, 2006 | 12:08 AM
@ries's Avatar
i say get them or else you may risk ripping out the rear sub frame thingy majiggy.
Old May 31, 2006 | 12:27 AM
K-Spec's Avatar
get it. if you make corner hard enough, you may break off your stock "L" brackets.
Old Jun 6, 2006 | 05:49 PM
mkazm83's Avatar
Default Re: Neuspeed "L" bracket question. (khalal538)
I got the brackets today but no hardware. Can I just reuse the bolts that mount to the frame and use my own bolts for the bushing to bracket mounting points?
Old Jun 6, 2006 | 06:15 PM
K-Spec's Avatar
yes, but make sure you use some beefy bolts when mounting the sway bar to the brackets.
Old Jun 6, 2006 | 06:48 PM
E-Money's Avatar
remember to tighten all bushings down on the rear sway with vehicle weight resting on the rear suspension
Old Jun 6, 2006 | 07:12 PM
mkazm83's Avatar
Default Re: Neuspeed "L" bracket question. (E-Money)
Thanks, does neuspeed provide new hardare to mount the brackets to the frame?
Old Jun 6, 2006 | 07:35 PM
K-Spec's Avatar
i think it does come with the brackets.
Old Jun 6, 2006 | 09:31 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">remember to tighten all bushings down on the rear sway with vehicle weight resting on the rear suspension</TD></TR></TABLE>
That's true with bushings, but why would you need to do it with a swaybar? It's free to rotate, so it's not going to bind or anything...
Old Jun 6, 2006 | 09:56 PM
SnlpeR's Avatar
^^^ its to set the angle in which the bar sits so there is no preload on the bar
and it doesnt matter if you use the beefiest bolts.....that sucker would still be able to tear out from the chassis
and it doesnt attach to the rear subframe
Old Jun 6, 2006 | 10:25 PM
Hawkze_2.3's Avatar
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">^^^ its to set the angle in which the bar sits so there is no preload on the bar
OK, but the bar rotates freely inside the bushings. Moving both wheels up or down at the same time makes no difference.
Maybe if you were to lift one wheel higher than the other and then torque the bolts you would have some preload, but not when they're at the same height.
Old Jun 6, 2006 | 11:43 PM
bad-monkey's Avatar
the oem hardware/bolts should be strong enough to hold the brackets/omega bracket-bushings.
i'd even argue that you didn't need the L's, but it's not necessarily a bad thing.
Old Jun 7, 2006 | 02:16 AM
SnlpeR's Avatar
your car doesnt site 100% flat
you tighten the brackets when the car sits "level" so there is no preload on the swaybar
iluvmyef9
Apr 3, 2008 12:32 PM
office888
Jan 30, 2007 10:59 AM
GS8HFL21
Feb 2, 2005 12:42 PM
PhatHardy
Feb 24, 2003 10:07 PM
