wire up distributor obd1 from ls to si
I have an lsvtec setup on my 95 integra. I have a 99si head on it. The ls distributor is on the Si head. I have a minor leak so i'm fixing it by replacing it with the 99Si distributor. I dont think the harness plugs will match up from my stock ls harness. Is there a way so I can wire this up? I've searched, and nothing. All help is appreciated. Thanks
stick with the LS dizzy until you find an odb1 distributor
i havent seen and conversion harnesses for the obd2 to obd1 distributors
Since one of the legs is cut so the Ls distributor will go on the head, isn't that the reason why its leaking? I mean the distributor isn't sealing all the way up cause i'm using the ls distributor because of the legs not bolting all the way up, right?
I have a leg chopped off of an LS dizzy on my GSR cuz its all the I had to use
just tkae the dizzy off, clean the o-ring and the hole it goes into and see if it leaks
there could be oil on either one causing it to not seal properly
Yeah I know what you mean, maybe its not sealed on correctly. I mean its an O ring, it shouldn't be cracked or anything but if it is..i'm sure they're a dollar something at the dealership. Thanks a lot, knowing you have the same distributor setup makes me feel more confident of not going to get this 99si distributor and having the trouble of wireing it up. You saved me 50$ hah! thanks niqqa
