Charcoal canister hookup...help.
Old Apr 14, 2002 | 11:17 AM
Mario's Avatar
Default Charcoal canister hookup...help.
First of all, thanks for clicking on this topic.
Here's my problem. I am in the middle of swapping in a j-spec Integra engine into my 00 Civic hatch. The problem arises when I realized that j-spec motors don't use a charcoal canister. So what do I do w/ the huge one hooked up on the Civic? Do I remove it or find a way to use it somehow?
Any suggestions will be appreciated, thanks.
Old Apr 14, 2002 | 12:04 PM
fixhondas's Avatar
Default Re: Charcoal canister hookup...help. (Supersonic DC2)
are you using the OBD2 ECU?
[Modified by fixhondas, 4:05 PM 4/14/2002]
Old Apr 14, 2002 | 12:08 PM
Mario's Avatar
Default Re: Charcoal canister hookup...help. (fixhondas)
I'll be using a jdm p73 ECU.
Old Apr 14, 2002 | 12:10 PM
fixhondas's Avatar
So JDM does not have charcoal canisters? You'll have to block off the line that feeds the canister- that would be easiest
Old Apr 14, 2002 | 12:58 PM
Mario's Avatar
Thanks for your suggestion.
One of the thing is that since jdm Hondas do not run a canister, they do not have the inlet nipple on the intake manifold for the line from the canister.
So I guess for the meantime I will just vent that line outside the car somewhere.
Old Apr 14, 2002 | 02:09 PM
fixhondas's Avatar
If the ECU does not have any provision for purging the canister- it will not purge. If it does, you can put the line anywhere along the intake piping before the throttle plate (as long as you are not running forced induction)
WeB
Mar 9, 2010 11:50 AM
slick jr
Aug 27, 2009 04:51 AM
UNforgivABLE
Feb 25, 2009 05:16 PM
Eli Mac 67
Jun 11, 2007 04:45 PM
PatrickGSR94
Aug 20, 2003 01:16 AM
