blowing (15a) ECU fuse on 95 EG
Whats up,
i put this into another thrad, but got no responces <------ !!
my buddy has a b16 in his eg hatch, gsr harness...
it keeps blowing ecu fuses....
it happens when he goes around corners (which makes me think its a loose wire rubbing on something, possible a power wire rubbing the frame?)
he has a VAFC in it (Crimed not soldered in the interior), and vtec hard wired (Crimped and shrimk wrapping in the interior), i know the engine harness is all done right, i did it, and everything is soldered and shrink wrapped....
I am simply out of ideas... Someone help me, help him!
Update: I took out the vafc (reoldiered and shrink wrapped now) May 31st 1:46pm
Modified by USDM EG at 1:47 PM 5/31/2006
I searched for you and saw a trend. Usually it was a wire that was touching an engine part (ie IM) or chassis and melted off the side of it, making it ground the ecu. I say go through your harness and look for any wires touching metal.
Good thread https://honda-tech.com/zerothread?id=1332324
Sounds to me that the culprit might have to do with a Vafc wiring. Go through the wiring again. My best advise would be solder and heat shrink. Turns out better in the long run.
Exact same problem happened to me when a passenger accident pulled the VAFC wiring on my ECU. I fixed it, but wasn't sure what the problem was. I think it was the ground wiring on the VAFC was going to the wrong wire.
Triple check the wiring.
B18PwdCivic
Northeast (Sales)
Oct 10, 2012 06:53 AM
