if i do a compression test what should each cylinder read
Old May 30, 2006 | 10:34 AM
mikeym's Avatar
Default if i do a compression test what should each cylinder read
i did one and mine read 1)100 2)100 3)95 4)100......is that good or bad
Old May 30, 2006 | 10:37 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: if i do a compression test what should each cylinder read (mikeym)
Thats pretty dam low... but what i have been told by instructors is that if they are primarily even and the engine runs fine not to worry about it. However that is pretty low... need info on vehicle to specify specs.
Old May 30, 2006 | 11:12 AM
cm zak's Avatar
Did you do it right? thats extremely low, yes even is good, but that low is weird.
Old May 30, 2006 | 11:15 AM
Lan's Avatar
Lan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">need info on vehicle to specify specs.</TD></TR></TABLE>
Are you doing it while the engine is warm? How many cranks are you giving it?
Old May 30, 2006 | 11:18 AM
Azn Kenny's Avatar
Did you do them at WOT too?
Amused
Oct 26, 2006 03:30 AM
joostan
Nov 29, 2005 07:01 AM
mr_mbuna
Dec 11, 2003 01:23 PM
Nighthawk GS-R
Sep 23, 2003 05:08 PM
Nate B
Jun 17, 2003 09:56 PM
