compression test results
just compression tested my b16a2 but am worried they are a bit low ,
1)199
2)190
3)180
4)190
every one else seems to be 200+ , and there is big difference from 3 and 1.
hoping to boost this engine soon
1)199
2)190
3)180
4)190
it should be fine. as long as there isn't a significant amount of difference (15+) among each its ok. I know 1 and 3 are almost 20psi off, but its relatively close with the others so it should be ok.
But you did do WOT when you did the test right?
. 190 is good
