Decided on Hondata Reflash
Old May 30, 2006 | 08:48 AM
vnvracing's Avatar
Default Decided on Hondata Reflash
ok ive decided on the hondata reflash for my 06 type s
but first i need a little more information on it from people who have it
ive read the info on their site and ****...but i am just looking for a little more
when hondata is installed i mean can it cause and serious/potential damage to the engine?
as far as it reving to high and valves leaking?
is it safe to bring it to the red when the reflash is installed or are u risking blowing the engine
and i don't mean just flooring the car and letting it bounce off the limiter
i just mean power shifting like racing
can it cause and potential damage?
Old May 30, 2006 | 09:08 AM
BlackSage's Avatar
Default Re: Decided on Hondata Reflash (vnvracing)
no powershifting
If you are that scared of it then just dont rev that high. You are talking about an increase of 300 RPM, you will be ok.
Old May 30, 2006 | 09:14 AM
vnvracing's Avatar
who said i am scared .....
are u scared?
im just seeing if people have any info
and if its safe...
Old May 30, 2006 | 10:29 AM
SuperSlow's Avatar
reflash will not cause potential damage. Bad driving causes damage.
Old Jun 1, 2006 | 07:49 AM
ReV LiMiT's Avatar
Default Re: Decided on Hondata Reflash (SuperSlow)
with the reflash you should be ok. that isnt what causes engine damage. beating the **** out of the car is what causes engine damage. you could have a bone stock type s, drive it everyday and abuse it, and have a blown engine within 15,000 miles.
Old Jun 1, 2006 | 08:30 AM
vnvracing's Avatar
what i am trying to say is if u take it to the red with reflash will it cause damage?
Old Jun 5, 2006 | 05:32 AM
ATL_06_DC5's Avatar
Default Re: (vnvracing)
I wonder what about smog test??? will the reflash give the car a ecl???
Old Jun 5, 2006 | 06:11 AM
Todd00's Avatar
I said I don't want a title!
If you are worried about it then just doon't rev that high, or don't do it very often.
Hondata helps out in other areas other than just more RPMs.
Old Jun 5, 2006 | 07:53 PM
gm3w12's Avatar
Default Re: Decided on Hondata Reflash (Todd00)
Reving that high will not hurt you... Over Reving the motor and bouncing off the rev limiter will hurt you... The JDM K20A reves to over 8600k so you'll be fine... Additionally, hondata says once you hit 10k rpm is when you would have piston valve touch which is very bad. In other words, there is nothing to worry about. Also, most of the power is made in the mid range so you can still shift at the stock limit. I am looking into getting this also but im just waiting to get some more funds together.
Old Jun 6, 2006 | 08:55 AM
ScuDC5's Avatar
the reflash will not cause damage. Any damage done will be by the driver. It adjusts the VTEC point and allows for a higher redline (the OEM meter is off by a few hundred RPM anyway as a safety measure) so you're still in a safe zone.
Again, this doesn't make you a good driver. Respect the car andit won't get damaged. The power was always there in the engine, Hondata just brings a bit more out.
Old Jun 11, 2006 | 08:36 PM
eskribble's Avatar
I was wondering about smog......Don't want "The Man" on my case
Old Jun 12, 2006 | 01:12 AM
simpledc5's Avatar
i have a question but still has to do with the reflash.if i put on race headers and had my cat removed on my rsx the engine light would come on and make the car unstable right?am i gonna need the reflash to make things right?is there a way around the reflash.or is that my best choice.thanks in advan.
Old Jun 20, 2006 | 08:51 AM
BlackSage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vnvracing &raquo;</TD></TR><TR><TD CLASS="quote">who said i am scared .....
are u scared?
and if its safe...</TD></TR></TABLE>
Calm down buddy. I wasnt trying to insult you. I meant that if you are worried/concerned/troubled by/scared of the higher rev limit there is no need for it. But dont take my advice, just dont rev that high. Just cause the redline is up there doesnt mean that is where you have to shift there.
And to back my first post and what everyone has said afterwards it is SAFE.
Have fun with it
Txdragon
Engine Management and Tuning
15
Apr 11, 2016 06:48 PM
08k20si
Honda Civic (2006 - 2015)
Jun 15, 2008 04:43 PM
johnclaunch
28
Jun 29, 2007 08:27 AM
ghostsi69
Sep 23, 2004 12:48 AM
$N@kE
May 29, 2003 11:48 AM
