What motor?
Old May 30, 2006 | 08:23 AM
wannarace's Avatar
Default What motor?
Need advice on what motor to get for my 95 civic eg. I currntly have an LS that i currently messed up. Wanting to go with something different with VTEC. Which motor would have the most HP and could handle a turbo. I a hoping to get around 300-350 HP.
Old May 30, 2006 | 08:28 AM
G2 Speed's Avatar
Default Re: What motor? (wannarace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannarace &raquo;</TD></TR><TR><TD CLASS="quote">Need advice on what motor to get for my 95 civic eg. I currntly have an LS that i currently messed up. Wanting to go with something different with VTEC. Which motor would have the most HP and could handle a turbo. I a hoping to get around 300-350 HP.</TD></TR></TABLE>
most horsepower
k series or h series
good luck
Old May 30, 2006 | 08:30 AM
tatmark1's Avatar
id spend your money by building and turboing what you have
Old May 30, 2006 | 08:33 AM
Out of every
Man this is the best ? i have ever seen! not 1 time have i ever seen this question on h-t. great post!
k, h, b, or turbo d. a d-series can handle 350 with some internal work done
you cant really go wrong with either of the ones listed
Old May 30, 2006 | 08:44 AM
-Gary-'s Avatar
LS1, oh wait, wrong forum.
Old May 30, 2006 | 10:05 AM
FalkenSiR's Avatar
Default Re: (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">LS1, oh wait, wrong forum.</TD></TR></TABLE>
and no vtec
To the op, I say if the damage isn't too bad on your LS, rebuild it for boost. If you do it right, it should be fun to have the same amount of tq as power
Old May 30, 2006 | 10:24 AM
SuperSlow's Avatar
j32.
Old May 30, 2006 | 10:32 AM
cyang08's Avatar
jsut replace the head with a Vtec head and boost it. Ls are pretty good for boosting cause they have pretty low compression
Old May 30, 2006 | 10:43 AM
Essenar83's Avatar
300-350 hp isn't that easy to get unless you're going for some good head/block modification.
I don't recommend a B16A.
In fact, I think you should just rebuild the LS since it's messed up anyway. It'd be much better for boost anyway, and the day-day drivability would be better.
blade0313
19
Jul 17, 2007 11:42 AM
Th3savinday
10
Dec 7, 2006 06:14 AM
areg
Oct 25, 2005 09:38 AM
ThaCivicAssassin
26
May 17, 2005 05:34 PM
Special-K-Coupe
Jan 24, 2005 09:22 PM
