Where is the oil pump?
Old Apr 14, 2002 | 10:00 AM
PatEJ6's Avatar
Default Where is the oil pump?
As some of you prolly remember, my timing belt had a few teeths missing in a row and many suggestions has been submited to explain why that happenned. I just checked today if the cam was turning and it does fine, I can make it turn with a rachet (12 mm socket). All the valves seems to work fine as well, at least from the outside. Now 94gsr told me in another post:
"Pull the valve cover & timing belt off & see if your cams both turn. If so, then it's your oil pump."
So now I would like to check out that oil pump, can anyone tell me where is that oil pump?
thanks,
Pat, getting closer to a fix
Edit: corecting mistakes, damn I hate laptops...
[Modified by SpeedyPat, 7:01 PM 4/14/2002]
Old Apr 14, 2002 | 10:21 AM
Mikey3000's Avatar
Default Re: Where is the oil pump? (SpeedyPat)
it's at the bottom right side of the motor (looking at motor from front of car). the crankshaft turns it.
Old Apr 14, 2002 | 12:26 PM
salbaje's Avatar
it is behind the crankshaft pulley under the plastic cover
Old Apr 14, 2002 | 01:08 PM
PatEJ6's Avatar
Default Re: Where is the oil pump? (salbaje)
so it's not the timing belt that make the oil pump turns right?
Old Apr 14, 2002 | 01:42 PM
PatEJ6's Avatar
well I just bought a service manual from amazon.com...
Old Apr 14, 2002 | 01:52 PM
supergreenNA1's Avatar
New User
nah.. the crank turns the oil pump.
Old Apr 14, 2002 | 02:01 PM
PatEJ6's Avatar
Default Re: Where is the oil pump? (supergreenSol)
so explain me the connection between a timing belt with missing teeths and the oil pump please.
My guess would be that the oil pump provide oil into the head and if it's not working then the cam heat inside the head and seize untill it cools down. That would explain the missing teeths on the belt and why now the cam is not seized.
Right?
Old Apr 15, 2002 | 07:19 AM
PatEJ6's Avatar
anyone?
Old Apr 15, 2002 | 09:25 AM
Mikey3000's Avatar
the timing belt takes this route: oil pump "pulley", tensioner, water pump, then cam pulleys. i don't think an oil pump can have anything to do with missing teeth on a timing belt. maybe you should take the car to a repair shop and have them check it out.
Fred Demara
Sep 12, 2012 09:18 AM
Egpower88
Jul 21, 2009 02:51 PM
boostedb1810psi
May 4, 2007 04:56 PM
ahobbs
Jul 1, 2006 06:26 AM
technine
Jul 2, 2003 05:59 PM
