question about taking off b-series head.
Old May 29, 2006 | 09:44 PM
Honda owner's Avatar
Default question about taking off b-series head.
my friend blew his motor a while back, and i went over there today, and took it out of the car, i was planning on stripping the motor down to the bare block to send to machine shop. but i ddidnt get very far.
i have a d-series, and to remove the cylinder head is very simple, but this is the first b-series ive ever worked on.. do i have to take out the camshafts just to get to the head bolts???
also i was removing the camshaft cover plate things, and i stripped one of the bolts.. and have tried using vise grips, and tried using a torche, but the sucker wont budge, should i just cut it flush, so i can remove the peice? any suggestions??
Old May 29, 2006 | 09:51 PM
Lan's Avatar
Lan
Default Re: question about taking off b-series head. (Honda owner)
Use an easy out for the bolt that is stripped. You'll need to get the cam caps off to pull the head so you can get the the head studs.
Old May 30, 2006 | 01:14 PM
Default Re: question about taking off b-series head. (Lan)
so i dont need to remove the camshafts? will i beable to get the head bolts once the cam caps are off?
Old May 30, 2006 | 01:16 PM
Lan's Avatar
Lan
I think so. Not absolutely certain though.
Old May 30, 2006 | 01:59 PM
ok thanks for your help
can someone comfirm this?
Old May 30, 2006 | 02:17 PM
Sam92Teg's Avatar
Think about what you are saying, if you have to pull the cam caps off, how much more effort is it to lift the cams out. And yes, cams must be removed.
Gunmetal_B20_Hatch
Oct 23, 2010 07:50 PM
spintboy
10
Mar 20, 2008 12:03 PM
MugenManR
32
Sep 24, 2006 12:11 AM
sacredc0w69
Nov 12, 2003 10:16 AM
shermanyang
Mar 29, 2003 11:02 PM
