gsr cams on turocharged B16?
hellooo
This link shows the earning produced by gsr cams on a ls vtec: http://forums.evans-tuning.com...+dyno think you that gsr cams on an engine B16 (built, turbo) the earning is significant?
thanks
Modified by kebroz at 8:40 AM 5/30/2006
thanks
Actually yes.. there has been some benefit due to the slightly higher lift/duration. About 40whp on applications under 600whp. Let me know if you need a set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Actually yes.. there has been some benefit due to the slightly higher lift/duration. About 40whp on applications under 600whp. Let me know if you need a set.</TD></TR></TABLE>
Thank you, I already have a set. What amazes me, it is that gsr has just a little less lift than B16 and lobes are very similar
thanks again.
thanks again.
the cams will make a noticeable difference. i had to go back to b16's from my gsrs and noticed a slight decrease in the ve of my motor
Friends of mine that have 1000whp civics say to use ITR cams and springs if you can get them, they provide the best results depending on how much power you want to make, and I hear some people are starting to go turbo with all motor cams to try and experiment a little bit, and it seems to be working if the tune is straight. I'm rocking ITR cams and springs and I like em' better than GSR cams in a turbo set up and I'm only making about 350whp right now. More boost later though 8-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurEvl »</TD></TR><TR><TD CLASS="quote">a gsr has less lift than a b16? where did u read that?
the lobes might seem similiar but when ran, totally different</TD></TR></TABLE>
i've a B16 and GSR(95) sets in my hands
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">the cams will make a noticeable difference. i had to go back to b16's from my gsrs and noticed a slight decrease in the ve of my motor</TD></TR></TABLE>
thanks,
but you've a B18 (long stroke) my question is, gsr cams can work fine on B16 engine? (more duration/less stroke
thanks again guys
thanks,
)thanks again guys
projectTeG
Feb 2, 2008 09:41 AM
joey1320
15
Jun 25, 2003 02:01 AM
