b18a1 max rpm
Old May 29, 2006 | 06:40 PM
b20vtechatch
Guest
Posts: n/a
Default b18a1 max rpm
I have a chipped pr4 ecu that has a 9500 rpm limit. my b18a1 has crower dual valve springs and t-retainers, ferera valves, and stock rods with arp bolts. whats the max rpm b18a1 rods can handle with arp bolts?
Old May 29, 2006 | 07:41 PM
FalkenSiR's Avatar
Default Re: b18a1 max rpm (b20vtechatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a chipped pr4 ecu that has a 9500 rpm limit. my b18a1 has crower dual valve springs and t-retainers, ferera valves, and stock rods with arp bolts. whats the max rpm b18a1 rods can handle with arp bolts? </TD></TR></TABLE>
If I had that setup, I wouldn't take it over 7500-7800 rpms depending on your powerband.
Old May 30, 2006 | 04:49 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b18a1 max rpm (fast95eg8)
just because of the rods? i know the head can take the abuse and so can the pistons and crank. oem crank and je pistons.
Old May 30, 2006 | 05:14 AM
mmuller's Avatar
Mad Scientist
mm i dont think there is a cam that will make power up that high in a non vtec motor...
the question is more like where do my cams drop off?
Old May 30, 2006 | 08:15 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b18a1 max rpm (mmuller)
so dyno it and see were my power starts dropping off?
Old May 30, 2006 | 08:20 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the question is more like where do my cams drop off?</TD></TR></TABLE>
As far as the rev limit goes, you will get a lot of different opinions. From personal expierence, 8500 is good if you have ARP rod bolts, Tri-metal rodbearings and a VTEC oil pump.
I'd go to 9000 with a balanced rotating assembly.
But, like mmuller said, It would be useless to rev high if you're not making power there.
Old May 31, 2006 | 07:29 PM
b20vtechatch
Guest
Posts: n/a
Default Re: b18a1 max rpm (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote"> As far as the rev limit goes, you will get a lot of different opinions. From personal expierence, 8500 is good if you have ARP rod bolts, Tri-metal rodbearings and a VTEC oil pump. </TD></TR></TABLE>
I have all those mods done, this is going to be a turboed engine im getting crower turbo cams when i get the turbo.
Old Jun 1, 2006 | 03:40 AM
NJIN BUILDR's Avatar
Because of the rocker design they often have problems over 8500 rpm.
Old Jun 1, 2006 | 07:50 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b18a1 max rpm (NJIN BUILDR)
im going 82 8500rpm thanks guys
Civic92Turbo
Mar 20, 2008 11:06 AM
hondapowaa
13
Nov 4, 2007 05:26 AM
hondapowaa
Nov 2, 2007 01:23 PM
jcvelez360
43
Aug 24, 2007 07:49 PM
pushinlsteg
Aug 9, 2005 10:23 AM
