Anyone have issues with Profec B Spec1's not holding high boost?
Old May 29, 2006 | 05:16 PM
mrbsponge's Avatar
Default Anyone have issues with Profec B Spec1's not holding high boost?
Just wondering if it is me, or if others have had the same problem, i have the old school Profec B Spec1 the one with the dials, not the one with the digital screen.
and at boost levels of like 20psi or more, it seems to want to fluctuate boost real bad, as if the controler cant keep up, and gate boost properly
anyone else had this issue?
this is the one i have
thnaks guys
Old May 29, 2006 | 05:18 PM
TurboTegB18c's Avatar
Default Re: Anyone have issues with Profec B Spec1's not holding high boost? (mrbsponge)
What psi spring do u have in the wastegate?
Old May 29, 2006 | 06:12 PM
Silverbeast's Avatar
I would definatley take that boost controller over the Spec 2 any day. Might want to move to a 10-12psi spring and it should be fine.
Old May 29, 2006 | 06:50 PM
mtber's Avatar
Default Re: (Silverbeast)
I have tuned several cars on the spec 1 without those kind of problems.
I would guess you could try a mbc to see if its an issue with the controller or not ?
Old May 29, 2006 | 07:05 PM
mrbsponge's Avatar
i have 9psi spring in my tial 38mm gate
im gonna turn it up abit and see what it does tomorrow, and if the timing issues may have had anything to do with it
Old May 29, 2006 | 07:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">I would definatley take that boost controller over the Spec 2 any day. Might want to move to a 10-12psi spring and it should be fine.</TD></TR></TABLE>
I've never had any problems with the profec spec 2. I acutally like it alot better then the spec 1 but the spec 1 works fine also. Definately shouldn't be having that problem with a 9psi spring and only 20 lbs of boost. Check into ur lines and make sure everything else is up to par.
Old May 29, 2006 | 10:31 PM
abnaasefmb's Avatar
Default Re: (TurboTegB18c)
make sure you have a good power supply and ground as well.
Old May 30, 2006 | 02:22 AM
lucidvtec's Avatar
try the gain control......that can mess you real bad...
also...how do u have the vacumm lines hooked up.....
Old May 30, 2006 | 05:43 AM
mrbsponge's Avatar
Default Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">try the gain control......that can mess you real bad...
i have the gain set to full sharp
and the vacuum lines are set up just like the diagram i got from thier site, the diagram is kinda odd but i did it that way and it has worked well up until now, till i went to go above 18psi
Old May 30, 2006 | 06:00 AM
sp00led's Avatar
Default Re: (mrbsponge)
I have the greddy profec Type-S. I guess it is a profec II but with analog ***** like the profec I. I always had issues when at just 10psi but I think that was related more to crappy internal wastegate. Hopefully on this new setup (shoping with Full-Race requires patience....) I won't have similar issues to what you are describing.
turbo95eg6
Jun 12, 2005 12:15 PM
Screamer
Mar 29, 2003 08:00 PM
SilverLudeSi
Nov 24, 2002 09:42 PM
accordfreak
Dec 25, 2001 12:20 AM
