ecu code question???
Old May 29, 2006 | 11:52 AM
Phrost's Avatar
Default ecu code question???
my 90 crx is throwing 2 codes 9 and 8 tdc position and no. 1 cylinder position but the car is running fine it just wont start once in a while but once its on it run strong it doesnt seem like that could be the problem. But where are those sensors?
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old May 29, 2006 | 02:44 PM
theinfamouskonrad's Avatar
Default Re: ecu code question??? (Phrost)
bad dizzy.
93b20z
May 18, 2009 04:59 PM
DA_Boy_626
Oct 3, 2007 06:50 PM
CustomX113
11
Sep 1, 2006 01:27 PM
kantfadedisazn
38
Feb 13, 2006 10:07 AM
xxthabest1xx
Mar 15, 2003 06:06 PM
