No Horn = No Cruise Control ??
Old May 29, 2006 | 09:34 AM
da_33's Avatar
Default No Horn = No Cruise Control ??
Ok I thought I remember reading somewhere about someones cruise not working then one day they installed the horn and it was working??
My crusie light will come on when I push the button but thats about it. I tried fixing the the pedal where there is suppose to be a piece of rubber under dash for the sensor, but no luck with cruise. So could maybe the problem be that I have no horn at all? When I pop off the cover there is nothing there. Any help would be great thanks
Old May 29, 2006 | 10:20 AM
trini-gsr's Avatar
Default Re: No Horn = No Cruise Control ?? (da_33)
the horn and the cruise control are on the same fuse, if i remember right. go under your hood and check the fuse box for blown fuses...
Old May 29, 2006 | 10:25 AM
R-81DC2's Avatar
Default Re: No Horn = No Cruise Control ?? (tnt-gsr)
It sound like the clock spring I had the same problem
Old May 29, 2006 | 10:31 AM
VHOA's Avatar
Default Re: No Horn = No Cruise Control ?? (R-81DC2)
its your fuse
Old Jun 1, 2006 | 08:49 AM
da_33's Avatar
Default Re: No Horn = No Cruise Control ?? (VHOA)
No its not my fuse i just checked them all. Their all good. I even looked closer at the brake and clutch pedal and both switches are being full compressed by the rubber stoppers... Any other ideas??
Old Jun 1, 2006 | 09:02 AM
DR Honda97's Avatar
fuse
Old Jun 1, 2006 | 09:27 AM
da_33's Avatar
did u not read what I just wrote I checked ever fuse under the dash they are all fine. and when I said I have no horn I dont mean it just doesnt work. I have no horn at all... When you pop off the acura cover there is nothing there but a empty space
Old Jun 1, 2006 | 08:47 PM
ITR#132's Avatar
Could have something to do with the cable reel (plugs not connected) when you removed your airbag.
Old Jun 2, 2006 | 08:17 AM
da_33's Avatar
Default Re: (ITR#132)
I have a 92 LS. I don't think it came standard with a air bag? and I also did not remove any of it. It is the way I bought the car but I remember the guy saying he like to try and do some of his own work and he was messing around with some electrical stuff.
Where is this cable reel located?
Old Jun 2, 2006 | 01:13 PM
R-81DC2's Avatar
Default Re: (da_33)
behind the steering wheel
Old Jun 2, 2006 | 01:46 PM
nahledge's Avatar
Default Re: (R-81DC2)
If you don't have an airbag on the oem steering wheel. Will your horn work? Or what do you have to do to make your horn work.
Old Jun 2, 2006 | 01:54 PM
f2rider's Avatar
Default Re: (nahledge)
I have a 98 LS with the same problem right now. I put in a new steering column and have not been able to use the cc or horn since. I do have an airbag and the srs light is on, what can you do wrong to the clock spring to cause all of this?
Old Jun 2, 2006 | 10:48 PM
da_33's Avatar
Default Re: (f2rider)
so behind as in up under the dash behind there or... ?
Old Jun 3, 2006 | 10:32 AM
da_33's Avatar
Old Jun 5, 2006 | 11:54 PM
kenzo42's Avatar
Default Re: (da_33)
When I removed my cruise control switch (box connected to the right of the steering wheel), my horn stopped working. I placed it back and the horn was fine.
It is needed for the horn to work, in my dc2.
Old Jun 12, 2006 | 11:26 AM
da_33's Avatar
-Championship-
Audio / Security / Video
Sep 30, 2006 10:46 AM
-Championship-
Sep 30, 2006 03:22 AM
JDM.Jay
Jan 4, 2006 03:05 PM
