sohc advice
is the d15 single over head even worth playing around with everyone keeps telling me to just swap it but i cant help but wanna do something to it anyway just to surprise people from time to time
its in a 93 hb si the engine was put it to basicly get the car moving and sold so thats what i have to work with for right now
when i bought the car i got it home and everyone started pecking on it someone pointed out my distributer was turned to advance or some crap and that u would only do that for turbo nos or super charger my car has non of these everything is timed good if i were to turbo it what are some things i should look into doing to my engine first
i was also looking into skunk2 manifolds and throttle body
having trouble tracking down some decent cam shafts for the d15b7 to
I had the same engine as you and if wanted you can be different and build up that motor such as turbo cams pistons. I did that with my d15 and it ran great wanted to go vtec so I swapped it for a d16z6 but i still have my d15 laying around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen18 »</TD></TR><TR><TD CLASS="quote">just swap the motor. It isnt worth blowing up your motor while paying $3000 for a turbo. just use that money for a b16 or something</TD></TR></TABLE>
your an idiot... a Dseries turbo kit can be put together for anywhere from 500 to 1000. and will destroy a b16.
so wat parts do i use and where do i get em.
do i get components off other cars?
also i have a d16y8 with bout 70k miles on it. how will it hold to 7 pounds of boost?
you can have a turbo kit for $500 = what hes really saying is do what half the ghetto kids do and go to your local junkyard pick up a crx HF manifold, mate a DSM turbo to it, DSM blow off valve, buy a used intercooler, and get your piping done at pep boys..dont do it, its just a waste of time..if your gonna go boost, do it right especially on a y8 if your goin under 10 lbs stock thats fine, but anything over that and your gonna need oil pump mods, and some other serious stuff.. y8's like to spin bearings at high boost due to oil starvation..before you do anything my advice would be to research and read up on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">running at around 7 pounds of boost will my engine see past 150k miles?</TD></TR></TABLE>
Sure! I guarentee it! ... that is if your motor is at 149,998 miles already
Im sure the d15 might get lame after a while. Swap engine, get good power, and if later you want to turbo lets say a b16 or w/e youll end up making even better numbers then you would on a d15. Im sure a d15 can be done right, but thats only for people that want to be different and do it for a challenge (and also really know what the fk they are doin)
the reason im asking is because the swap i was gonna get got bought right out from under me...well traded for a stock crx it was a b16 with gsr internals crx pistons gsr transmisson stage 2 clutch or some **** axles mounts the whole nine yards but danni need a car so he bit the bullet and let it go
i guess sence the one openly available complete swap for under 2000 dollars is gone now im just trying to be orginial with this engine is anyone running a decent d15b7 currently
what have u done and was it necessary to keep up with a stock b16?
my main problem is a guy i hang out with has the b18c5 integra type r engine in his civic coupe and he keeps blowing my doors off only person i have to be faster than is him ive got inferior hp complex
93eghb
57
Feb 17, 2008 07:04 PM
