gsr trans question
Old May 29, 2006 | 07:36 AM
conceptEG's Avatar
Default gsr trans question
ok.. i pulled my car out of the local grocery store..i got to 4500 rpms in 2nd gear not running it hard just your avg pull out i guess.. my trans made a poping(just 1) sound as if something jarred loose.. now makes grinding sound.. wont move.. i took it home and theres a finger thick gap between the axel and trans.. i can get my finger in between the 2.. no oil has come out and now it will turn the wheel but makes a bad grinding sound as i start to release the clutch... im thinking its the throw out bearing.. i still have all my gears..i just wanted to get an idea of what it could be before i start tearing it apart..have any of you had this issue??
the clutch operates..
it will turn the wheels over but as i start to grind as i release the clutch so i just shut it down to keep from damaging it any more..
ideas and opionions please
Old May 29, 2006 | 08:40 AM
lVlemphizStylez's Avatar
Default Re: gsr trans question (hatr-aid)
gap between axle and trans??? grinding sound??? sounds like your axle popped out...easy fix...get something and knock it back in....itll snap into place...in fact I KNOW thats what your problem is....just put the axle back into the tranny...push and twist...it should click into place
osix
Dec 13, 2015 08:28 AM
tico
Jun 23, 2010 08:20 AM
mikeycivic
Aug 3, 2008 02:31 PM
ProJectCvic
Feb 22, 2004 07:25 PM
Mar_DC2
Jul 18, 2003 01:47 PM
