Rear Disc Brakes questions
I'm a noob. I DID search but came up with no results pertaining to my specific questions.
I have a 99 Civic. One of my friends has a 90-93 Integra with disc brakes. I wondered if they would fit my civic.
Also, I'm looking to install a B16 into it. I didn't want to touch the block at all and only do some mild modifications to the head (i.e. cams, cam gears). I wondered if anyone could give me an idea as to how much horsepower and/or torque I would be making. TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">hmmm.... you have not checked the FAQ stuck at the top of the forum then....</TD></TR></TABLE>
Ok, the FAQ at the top are about what engine swaps are available. I already know that. I already know what I'm putting in. I just wondered if anyone has had any experience with B16's and mild headwork.
That wasn't the real point to this topic though. I wanted to know about the brakes which is why the topic is stated as such. Thank you to those who answered my brake question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">you need 94-00 integra brakes</TD></TR></TABLE>
all rears are the same - the da's will fit fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vallary99 »</TD></TR><TR><TD CLASS="quote">Ok, the FAQ at the top are about what engine swaps are available. I already know that. I already know what I'm putting in. I just wondered if anyone has had any experience with B16's and mild headwork.
That wasn't the real point to this topic though. I wanted to know about the brakes which is why the topic is stated as such. Thank you to those who answered my brake question.</TD></TR></TABLE>
Too bad you don't really know how to read.... like the 5 comprehensive threads within the FAQ that deal with brake swaps....
children...
children...
What about the rear control arms from the 93 Integra. Will they work on my 99 Civic?
BTW, when your FAQ pages about swaps contain 30 pages of unneccesary BS that have nothing to really contribute to the FAQ itself, it makes it extremely hard to read through. Maybe clean that up some and people will use the search a little more and use the FAQ.
Don't be an *** dude, the FAQ is very comprehensive. All of the threads are listed at the top.
Maybe you just need to learn how to read?
to trial users who know everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vallary99 »</TD></TR><TR><TD CLASS="quote">What about the rear control arms from the 93 Integra. Will they work on my 99 Civic?</TD></TR></TABLE>The less you swap, the less likely it is you will encounter fitment problems, and problems concerning "bad" parts (bent arms, cracked bushings, rust). For a Rear Drum to Disc Brake Conversion, all you really need from the Integra's Arms are the Spindles. Most people, however, swap the entire Trailing Arm Assembly.
For the Rear, there is a Trailing Arm (which includes the Trailing Arm Bushing and Spindle), a "Compensator" Arm (also called a "Torque" Arm), and **2** "Control" Arms (Upper and Lower)... To which "Control" Arm are you referring? Again, the less you swap the happier you are likely to be. There aren't many reasons to swap the LCAs or UCAs for this conversion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vallary99 »</TD></TR><TR><TD CLASS="quote">BTW, when your FAQ pages about swaps contain 30 pages of unneccesary BS that have nothing to really contribute to the FAQ itself, it makes it extremely hard to read through. Maybe clean that up some and people will use the search a little more and use the FAQ.</TD></TR></TABLE>The first post of the "Helpful FAQ" thread is periodically updated with links to the helpful FAQs, and serves as the "Archive". Subsequent posts are either pending additions, or mindless dribble. You don't have to wade through all 11 pages to find what you might need (make sure you're looking at the "FAQ" sticky, not the "Swap" sticky)... Here are some relevant links from it...
https://honda-tech.com/zerothread?id=152884 - Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=641639 - EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752 - How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639 - Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365 - Integra Brake Swap
https://honda-tech.com/zerothread?id=1625394 - Brake System Differences: EM1 vs. EJ8
I hope you find what you need...
JasonGhostz
JasonGhostz
Thank you JasonGhostz, that was really helpful. I guess I wasn't looking in the right spot because the only FAQ I saw was about the engine swaps and I searched for "brakes", "rear brakes", "integra brakes", etc. and came up with very little.
Chyno
Oct 8, 2004 10:27 AM
