running hot
Old May 28, 2006 | 08:15 PM
B_radGSR's Avatar
Default running hot
I have a B18c with the following mods:
Peakboost turbo kit
3" turbo back exhaust
525cc injectors
Walbro 255 fuel pump
t3/t04e .57 trim
stock radiator with electric fan
Central Florida Turbo tuned on crome at 9psi
The problem im having is running hot at highway speeds like 70-80 mph.....it runs normal at idle and even city driving. It's not even a problem when i run it hard....it's just at cruising speeds.....Any suggestions of what could be causing this???
Old May 28, 2006 | 08:50 PM
adseguy's Avatar
Default Re: running hot (B_radGSR)
did you touch the radiator when you installed the turbo setup? If not, I'd say headgasket issue, but my first guess would be an airbubble in the system.
Old May 28, 2006 | 08:59 PM
eg:R's Avatar
i had the same problem on the highway. took it back to my tuner. i forgot if he took or add timing around the highway rpm range
i try a new radiator first and it did not work for me so i took it back to my tuner. so far so good
Old May 28, 2006 | 10:01 PM
B_radGSR's Avatar
had the issue on the way to the tuner....they found some air bubbles and got them out, but still happening....it doesn't get to the red...just half way b/n red and normal
kuja396
Sep 11, 2007 04:40 PM
C8V6C
Jul 3, 2006 07:45 AM
EXACCORD95
Jul 25, 2005 12:27 PM
kun3racer
Oct 21, 2004 01:48 PM
FOrSfEd
Feb 5, 2004 04:48 PM
