questions for those with knowledge
Old Apr 13, 2002 | 09:00 PM
BOO YEAH's Avatar
New User
From: Witty Comment....., Stunning Response...., Follow Up Gag.....
Default questions for those with knowledge
O.K. I need to know a CRX 87 with a turbo b18 weighing about 2000lb with slicks,
head work, stroker kit, short throw shifter and a clutch,
what kind of times would you get?
Second thing, i am going to build a car like that and if you were building a turbo b18 what would yeild the most HP,
_______
Old Apr 13, 2002 | 09:12 PM
89 CRX SI's Avatar
Default Re: questions for those with knowledge (BOO YEAH)
Well it would beat your camaro. Very fast it would be almost unstreatable. Very fun to drive tho. Good luck. Prolly mid 11's low 11's on slicks with good driving etc.
Old Apr 13, 2002 | 09:18 PM
Mugen Dom's Avatar
wut kinda b18???ABC1,C5? wut kinda turbo it can be streetable make sure its a si it wont work other wise....if u dont know much about hondas research how to do swaps and ur gonna need to rewire a bit for obd and all....teh car weighs about 1800 or less if u strip it down it can be a 9 sec car if u have the loot
Old Apr 14, 2002 | 07:37 AM
BOO YEAH's Avatar
New User
Default Re: questions for those with knowledge (jdmB18hatch)
ok it should weigh in a 200lb the block will be the new dart block i beleve it is a b16a so i know it will fit the weight reason is it will have a few extra goodies i cannot disclose at this time, but i would like to know how much power can you make from one and still street it?????? streeting it does not mean running it on theboost all the time i would probably make the wastegate blow at 10-14 psi on he street, and i know traction is a problem on the street but i can handle that
thanks for any responses
Old Apr 14, 2002 | 07:47 AM
BOO YEAH's Avatar
New User
the b16a will have a stroker kit to 2.0l, major head work, turbo set up vtech cams, stand alone management...i beleive my friend said aem had the best???, lightweight rims with 275 widthe tires or what ever will fit, frontmount intercooler, turo, short thow shifter(not stock tranny), as well as the best parts made for hondas, extrude honing and all that good stuff, fuel cell, rollcage, so with that how much power and how fast at 2000lb
Old Apr 14, 2002 | 07:48 AM
BOO YEAH's Avatar
New User
you said i need to rewire for obd????? what if i get a standalone computer and don't plan on cats and other wasteful stuff????
Old Apr 14, 2002 | 08:08 AM
Ltech's Avatar
How much money are you planning to spend?.
Old Apr 14, 2002 | 08:29 AM
Mugen Dom's Avatar
Default Re: questions for those with knowledge (Ltech)
yeh for real talkin haltech??hondata?? wut man if u goin standalone u should know wut ur doin i guess and not be askin how fast willl this go? and it also depends if u can drive
Old Apr 14, 2002 | 04:17 PM
BOO YEAH's Avatar
New User
well the time on my camaro is on streets with no internal mods or power adders, i am thinking aem computer
Old Apr 14, 2002 | 04:19 PM
BOO YEAH's Avatar
New User
by the way that was a .532 RTand a 1.7 60'
Old Apr 14, 2002 | 05:18 PM
89 CRX SI's Avatar
thats prety damn good.
Old Apr 14, 2002 | 06:25 PM
BOO YEAH's Avatar
New User
Default Re: questions for those with knowledge (89 CRX SI)
that is on potenza re070 275/45/17
but anyways beinge ridiculous using almost the best parts witha budget of 11 grand n the motor alone what should i do???? I know turbo, and stroker, but what parts??? I know jack about hondas just have a cool idea and huge tax return......
Old Apr 14, 2002 | 08:02 PM
Mugen Dom's Avatar
well like i said research it man ur talkin stupid really strokin a b16 ???? why do it teh motor has a almost perfect rod stroke changing the stroke will increase ur chances of slamming a piston into ur vavles.... learn before u do im speakin to u as someone who is in teh process of builing a motor do it right and teh aem computer look into haltech or hondata aem replaces teh newer obd2 ecus and such u donot have obd1 even just research and if u dont know alot get a 88-91 crx the 87 will be more of a hassle for u if ur not to knowedgable
Old Apr 14, 2002 | 09:18 PM
rioninja's Avatar
http://www.zdyne.com http://www.goldeneaglemfg.com http://www.crower.com http://www.theoldone.com/components
when i read this post i though either
a] this has to be a joke or,
b] you really dont have ANY idea what your doing
You cant just drop 11k and have a fast car, its gonna take months of getting parts together. I would first research which motor you want to start with, i would recommend either a sleeved B16a or B18c. You'll probably do better to start with a first gen B16a swap. This will be the absolute easiest to work with your car as the electronics will be compatible. If your dropping it in an 87 CRX, make sure its an SI like JDMB18hatch said (only model w/ fuel injection). You will need a ton of other things, such as mount kit, clutch kit, decent axles, etc. Please post more specific questions
Judg3
Jun 27, 2008 06:33 AM
poorboyimports
May 4, 2006 08:11 AM
BOO YEAH
Apr 15, 2002 10:37 PM
BOO YEAH
Apr 13, 2002 08:49 PM
civbeater90
Dec 1, 2001 05:57 PM
