H22a JDM swap civic 93HB wiring problem
Old May 28, 2006 | 02:22 PM
grodzio's Avatar
Default H22a JDM swap civic 93HB wiring problem
I have a problem with wiring ! I bought a Prelude H22a engine with all wires and ECU from that car. The engine is instaled i my 93HB. All wires from engine to ECU are connected ,but I dont know how to connect wires from ECU to (switch) equipment in my car (lights,windows,horn etc.) Maybe somebody know how to do it ,have some pics of this work or something ?
Thanks for any help !
Old May 28, 2006 | 03:25 PM
under_psi's Avatar
Default Re: H22a JDM swap civic 93HB wiring problem (grodzio)
is this an OBD2 harness?....anyways, best is to use your stock harness, you'll have to extend a few plugs and add vtec solenoid, vtec pressure switch, knock sensor, EGR and IAB's. use the plugs and length of wires from the prelude harness.
Old May 28, 2006 | 11:08 PM
grodzio's Avatar
Default Re: H22a JDM swap civic 93HB wiring problem (under_psi)
I dont have OBD2 harnes what am I do ?
Old May 28, 2006 | 11:26 PM
JDMRice's Avatar
Need more info as what u need help with, is the motor obd1?
If so like the other poster posted extend a few plugs add a couple wires run them to your ecu, and thats it. Lights windows and horn I believe run on a different harness, has nothing to do with the motor harness.
Old May 29, 2006 | 12:09 AM
grodzio's Avatar
Default Re: H22a JDM swap civic 93HB wiring problem (SohcPower)
I had d13b2 motor... i dont thing that other harness will fix into the ecu gap.
Old May 29, 2006 | 01:17 AM
JDMRice's Avatar
dont use the prelude harness, its easier to use youu stock harness that was on your old motor, just take it off(make sure u label where each plug goes) then put it on the h22 motor, your going to have to extend several wires, plus add the the wires for vtec vtec solrnoid etc. and run them to the ecu., and might have to change a plug or too. Look in the faq, all the info is there.
Old May 29, 2006 | 03:24 AM
grodzio's Avatar
ok I will try ,thanks for help
95ludeSE_bottle
Jan 8, 2009 07:17 AM
Bambinoh
May 5, 2007 11:43 PM
jdawgg
Jul 3, 2006 06:06 AM
pchee373
Apr 12, 2006 01:08 PM
sicklude94
Sep 28, 2004 08:42 PM
