need to know if my pressure plate is bad or my transmission is bad
Old May 28, 2006 | 01:31 PM
P-DuBB's Avatar
Default need to know if my pressure plate is bad or my transmission is bad
need ht members help, my car wont move, it start but wont move, i think its the clutch, but not to sure, when i start the car it wont go into any gears, feels like something jammed in there, but when the car is off its goes in to gear fine ....i tried to put it in gear and start it but it would start for like a second and die, and it would get stuck in gear, and is really hard to get out.......so my question is .....it my clutch or tranny...
any info would be great..... please help
P-DuBB's Avatar
Default Re: need to know if my pressure plate is bad or my transmission is bad (P-Dubb)
please help
Old May 28, 2006 | 05:14 PM
P-DuBB's Avatar
anybody
Old May 29, 2006 | 08:07 AM
Smoke_em's Avatar
From: Inland empire, E.L.A, Douglasville GA, ca, u.s
not really sure but . i would lean more on ur clutch. did u do a clutch job on it or it just started doing it ?if u didnt . then againm ight be ur tranny went bad.?. but try the easy things first been ur clutch
Old May 29, 2006 | 09:10 AM
P-DuBB's Avatar
Default Re: need to know if my pressure plate is bad or my transmission is bad (Smoke_em)
this is the first time, i think it might be the clutch
Old May 29, 2006 | 09:17 AM
b18sihatch's Avatar
i had the same exact problem, the throw out bearing was *******. when the car was off it would go into every gear, turn the car on and it wouldnt go into ANY gear. sometimes it did but grinded . definitly is a clutch related problem
Old May 29, 2006 | 09:27 AM
P-DuBB's Avatar
Default Re: need to know if my pressure plate is bad or my transmission is bad (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i had the same exact problem, the throw out bearing was *******. when the car was off it would go into every gear, turn the car on and it wouldnt go into ANY gear. sometimes it did but grinded . definitly is a clutch related problem </TD></TR></TABLE>
thanks for the info
Old May 29, 2006 | 03:14 PM
P-DuBB's Avatar
took the tranny off today and a piece that holds the spring on the clutch broke off....problem sovled................thanks ht memeber for all your info
brian_ek
Transmission & Drivetrain
Mar 20, 2015 07:23 PM
Matt Royer Jr.
Mar 25, 2013 11:15 AM
oramac_eg
Dec 30, 2009 10:00 AM
bonta-kun
Oct 9, 2006 11:31 AM
SonicRacing
Feb 26, 2006 01:54 PM
