obd1 motor obd2 car SMOG IN AZ?
i have a obd1 b16a with a p30 ecu in my 96 civic, used obd2 harness, throwing knock sensor code...if i get a p28 or get it chipped to ignore the knock sensor, could i get it smogged with the obd1 ecu? or would i need an obd2 ecu? would the obd2 ecu throw codes on an obd1 motor? what im trying to find out is if i will need to change the oil pump and crank sensor to obd2..az is different than ca far as smog goes im pretty sure.
thanks in advance.
thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">im aware of that homie, im wondering if they will run it on the dyno like the rest of pre obd2 dars.
someones gotta know. up.</TD></TR></TABLE>
Why dont you call or visit a local smog place and find out the exact info you need to know?
I know that in CA, if you own an OBD2 vehicle, there's no way in hell you'll pass using an OBD1 ecu. The OBD2 scanner tool will not communicate with an OBD1 ecu.
An OBD2 ecu will work with an OBD1 engine, throw CEL codes if it's not satisfied about something.
Yes, if you get a P28 or have the P30 ecu reprogrammed with a disabled KS, it won't look for the KS.
about the CKF sensor, check out the CKF bypass trick on my techsite:
http://technet.ff-squad.com/ckftrick.htm
so i was thinking, could i use my obd2 d16y8 ecu? i ran it with the b16a and the only difference i see is the 7k redline. anyone know if this will work? if not, what ecu would be ideal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">awesome, thanks man. so will they be able to run an obd1 with an obd2 ecu as an obd2 car?</TD></TR></TABLE>
you mean, be able to run an OBD1 engine in an OBD2 car w/an OBD2 ecu?
You might be able to get away with this, I don't know for sure, but make sure you have the 2nd 02 in working order, do the CKF trick, and run the OBD2 smog equipment that came with the OBD2 vehicle.
strictly.business
Nov 25, 2006 09:05 PM
