Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
SSR Comp H, Comp X, Competition, Type-C
Old May 27, 2006 | 05:17 PM
KOREAN's Avatar
Default SSR Comp H, Comp X, Competition, Type-C
What's the difference between the structure of these rims?
Competition
Comp H
Comp X
Type-C
Old May 27, 2006 | 05:19 PM
trick_db's Avatar
Default Re: SSR Comp H, Comp X, Competition, Type-C (korean)
all look the same to me.. just that different name cuz different color?
Old May 27, 2006 | 05:21 PM
__oversea's Avatar
something to do with year. or model type- offset limit, wide limit, made with cast, froged, ect.
Old May 27, 2006 | 05:39 PM
KOREAN's Avatar
Default Re: SSR Comp H, Comp X, Competition, Type-C (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">something to do with year. or model type- offset limit, wide limit, made with cast, froged, ect. </TD></TR></TABLE>
froged rims ftw!
I've been searching, but I can't find a difference :/
Old May 27, 2006 | 05:53 PM
743power's Avatar
type c and competition are the same, competition is just for US market.
comp x are stronger, for rally racing I believe, mainly in 5x100 for subies
not sure about h
Old May 27, 2006 | 05:57 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: SSR Comp H, Comp X, Competition, Type-C (743power)
Comp H are only 15X7, but all are forged. No major diffrences.
Old May 27, 2006 | 06:20 PM
KOREAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">type c and competition are the same, competition is just for US market.</TD></TR></TABLE>
My friend said they look different, but I was thinking he probably just compared different offsets, therefore showing a different spoke concave.
Thanks everyone!
Old May 27, 2006 | 07:12 PM
jamesracing's Avatar
The way the metal if forged can be the difference. The type-c's are light weight. The 15x7 are only 10.3 lbs.
Also, you can't tell by a pic if the inside of the fork's are gutted or not. Two wheels might look identical from the outside but flip them over and the fork's and/or other parts of the wheel may be hollowed out slightly. Some factory miata wheels are like this. Just feel around the fork, one might be solid while another set is hollowed out. (the hollowed out wheels being the light weight wheels)
Separated the two
Modified by jamesracing at 7:53 AM 5/28/2006
Old May 27, 2006 | 09:47 PM
Reid's Avatar
Global Moderator
Default Re: SSR Comp H, Comp X, Competition, Type-C (jamesracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamesracing &raquo;</TD></TR><TR><TD CLASS="quote">The way the metal if forged can be the difference. The type-c's are light weight. The 15x7 are only 10.3 lbs. Also, you can't tell by a pic if the inside of the fork's are gutted or not. Two wheels might look identical from the outside but flip them over and the fork's and/or other parts of the wheel may be hollowed out slightly. Some factory miata wheels are like this. Just feel around the fork, one might be solid while another set is hollowed out. (the hollowed out wheels being the light weight wheels)</TD></TR></TABLE>
FWIW, I've got 13 SSR Competition wheels and 4 SSR Type C's and none of them have hollow spokes.
Old May 28, 2006 | 06:50 AM
Default Re: SSR Comp H, Comp X, Competition, Type-C (Reid)
FWIW, I have the 1 set of type-c's and they aren't hollowed out either. Never said they were. Point being you can't tell the difference of two different wheels by looking at a picture on the e-net.
Old May 28, 2006 | 09:10 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
FWIW, I've got 13 SSR Competition wheels and 4 SSR Type C's and none of them have hollow spokes. </TD></TR></TABLE>
What differences do you see between the Type C's and the Competitions?
Old May 28, 2006 | 05:06 PM
euro's Avatar
Default Re: SSR Comp H, Comp X, Competition, Type-C (George Knighton)
FWIW I have (3) 17 x 7.5 SSR comps 4 x 100mm and I desperatly want to buy a forth if anybody happens to have any. I will buy 1, 2, 3 or 4 wheels.
One got bent at VIR in feb.
Old May 29, 2006 | 05:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
What differences do you see between the Type C's and the Competitions?</TD></TR></TABLE>
I am curious as well?
Old May 29, 2006 | 05:46 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">What differences do you see between the Type C's and the Competitions?</TD></TR></TABLE>
A "Type C" is the same wheel as a "Competition". The only difference is the name. Competitions are only sold in America.
Old May 29, 2006 | 05:47 AM
Reid's Avatar
Global Moderator
Default Re: SSR Comp H, Comp X, Competition, Type-C (euro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euro &raquo;</TD></TR><TR><TD CLASS="quote">FWIW I have (3) 17 x 7.5 SSR comps 4 x 100mm and I desperatly want to buy a forth if anybody happens to have any. I will buy 1, 2, 3 or 4 wheels.
One got bent at VIR in feb.</TD></TR></TABLE>
What size/brand of tyre were you using when it got bent? I got a minor bend in one of my 17x9 SSR Competitions from too much curb hopping while running 255/40/17 V700's.
Old May 30, 2006 | 05:16 AM
euro's Avatar
I was running a very weak size: 205-40-17, toyo RA-1,
/Greg
Old May 30, 2006 | 05:37 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euro &raquo;</TD></TR><TR><TD CLASS="quote">I was running a very weak size: 205-40-17, toyo RA-1,
/Greg</TD></TR></TABLE>
How bad was the bend?
When I bent a wheel, it still held air and balanced fine.
Old May 30, 2006 | 05:40 AM
euro's Avatar
completly unusable. At first I thought wow no big deal All i saw was a bent inside lip so I sent it to a wheel repair place. Came back unrepairable. I pull it out of the box lay it on the floor and then i noticed it. The thing wobbled back and forth on the flat floor about 1/4". Bent the lip and tweaked the entire wheel.
JoshuaVTEC
Jan 16, 2006 07:23 AM
DannyITR
Mar 22, 2005 04:07 AM
cd5_2NR
Feb 6, 2005 11:01 AM
bbadillo
Dec 14, 2003 10:48 AM
itduzntmatter00
Jul 5, 2003 12:26 PM
