Question on turbo cam and idle
Old May 27, 2006 | 04:10 PM
b*saint's Avatar
Default Question on turbo cam and idle
Turbo cams should pose no threat on the idle right? Because of the short overlap it should idle like a stock engine? I did a search but couldn't find anything so excuse if this has already been covered.
Old May 27, 2006 | 04:31 PM
akstunt600's Avatar
it still depends on how aggressive the cam is.
the longer the duration
the more overlap ur gonna have
a stage 3 will still have a lil bit of a rough idle
but i have put stage 5 503 lift crowers in a n/a gsr and it still idles, but it just barely cuts as a daily driver.
just choose the right heat range for ur plugs and gap them accordingly
for turbo i would use ngk-r 9
Old May 27, 2006 | 07:41 PM
b*saint's Avatar
Default Re: (akstunt600)
Well I mean witha turbo cam spec. I know high rpm NA cams have tons of overlap, but turbo cams don't. So it shouldnt be a idle problem, but what about the high lift?
Old May 28, 2006 | 06:54 AM
akstunt600's Avatar
well turbo cams r still closely related to n/a cams the duration is long to bring in more air but slightly shorter on the ex to get higher ex pressures to help with turbo spool
u r still going to have some idle issues but it will still be daily drivable.
stage 3 will be perfect and has a moderate amount of overlap at idle
iMPoRT GeeK
Jul 29, 2007 12:32 AM
yellowhonda88
Jan 12, 2007 05:13 PM
Urugly
Aug 26, 2006 09:35 PM
Yusuke
Dec 30, 2004 08:09 AM
Mr.DC2TurBo
Sep 5, 2004 06:42 PM
