Wire harness for aftermarket HU in navi car?
Old May 27, 2006 | 05:02 AM
BleedTheFreak's Avatar
Default Wire harness for aftermarket HU in navi car?
DOes the usual wire harness you get from CC or BB work when installing an aftermarket head unit in a 2003+ navi car or would I need a special harness to install it? If so, what to get & where do I get it?
Old May 27, 2006 | 08:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wire harness for aftermarket HU in navi car? (BleedTheFreak)
It is the same adapter harness.
What exactly are you trying to do, to what car, with what in it now, and why? 94
Old May 29, 2006 | 06:52 AM
Default Re: Wire harness for aftermarket HU in navi car? (fcm)
Install an aftermarket head unit in a 2003+ Accord w/navi.
Old May 29, 2006 | 03:58 PM
fcm's Avatar
fcm
Old Fart
OIC, get rid of the screen and install the aftermarket HU, have you looked at other options like JL Audio OEM interface... http://mobile.jlaudio.com/prod...id=94 or do you already have the aftermarket HU? 94
Old May 29, 2006 | 06:41 PM
Get rid of the screen? Why the hell would I get rid of the screen for the navigation system?!
I would install the head unit in the storage area below. I would be using my Pioneer head unit that I'm taking out of my old car.
I'm still looking for an answer to my question folks...
Old May 30, 2006 | 09:55 AM
vicn77's Avatar
i know metra makes a kit for the replacement dash kit for the pocket underneath. i forgot what the model number is but in that dash kit it also comes with a t-connection for you the radio. i've never put one in with a nav system, but the dash is still functional except for the radio sound. i think it just piggy back the constant 12v, acc wire and ground and reroutes the speaker wires for the new HU.
the part number is:
99-7862 for the dash kit/harness
70-1721T for the wire harness by itself
Old May 30, 2006 | 04:29 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BleedTheFreak &raquo;</TD></TR><TR><TD CLASS="quote">Get rid of the screen? Why the hell would I get rid of the screen for the navigation system?! </TD></TR></TABLE> That's why I asked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BleedTheFreak &raquo;</TD></TR><TR><TD CLASS="quote">I would install the head unit in the storage area below. I would be using my Pioneer head unit that I'm taking out of my old car.</TD></TR></TABLE> Yes you can you will need 2 harness, the adapter for the cars harness and a rev. adapter... http://www.metraonline.com/pro...0Wire or this... http://www.metraonline.com/pro...0Wire or this... http://www.metraonline.com/pro...0Wire you will also need a 4PDT relay and a SPST relay, so you can switch the speakers between the 2 units, [4PDT] and turn off the oem unit when you turn on your Pioneer, [SPDT].<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BleedTheFreak &raquo;</TD></TR><TR><TD CLASS="quote">I'm still looking for an answer to my question folks...</TD></TR></TABLE> Read above. 94
Old Jun 3, 2006 | 08:42 AM
None of those harnesses say anything about navi so I assume there is no special harness needed for navi cars?
Old Jun 3, 2006 | 09:17 AM
fcm's Avatar
fcm
Old Fart
And none are shown at Metra online or Scosche. 94
Old Jun 3, 2006 | 10:30 AM
That dual to single zone harness you linked. DOes that eliminate the dual zone controls?!
Old Jun 3, 2006 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Yes I believe it does, but your not going to use it that way, because you want to run both the OEM system and your aftermarket HU, you will need to switch the speaker leads between the 2 units, so when you are on the oem system the speakers are wired to it and when you want to play your aftermarket HU the speakers will be connected to it, there are 8 speaker leads to deal with a pos. (+) and neg. (-) for each speaker, so you will need two 4PDT relays and one SPDT relay, you will also need the oem radio harness adpt. plug to plug into the cars harness and the "reverse" harness that plugs into you oem HU/nav. system, using the harnesses will make putting the "switcher" together a lot easier, and you will not need to cut any oem wires. 94
Old Jun 4, 2006 | 02:36 PM
I'm still a bit confused lol
& where do I get these relays?
Old Jun 4, 2006 | 06:37 PM
fcm's Avatar
fcm
Old Fart
You can't wire two amps to the speakers, [amp in OEM HU and amp in the aftermarket HU, so you have to install a switch on the speaker wires so only the unit you are using will be connected to the speakers.
The SPDT relay you can get at any car audio shop, or car parts shop, the 4PDT relays may be a little harder, any electronics supply store should have them, they look like this... http://catalog.tycoelectronics...18233 but would be 12VDC. 94
Old Jun 5, 2006 | 04:32 PM
What about this harness?
http://www.discountcarstereo.c...D=787
Old Jun 5, 2006 | 05:36 PM
fcm's Avatar
fcm
Old Fart
That harness gives you an aux input to the oem system it and/or a RCA adpt. like the one below it would allow you to plug your aftermarket HU into the oem systems aux input, [you will not be using the amp in the aftermarket HU] and use it as a "slave' unit. It would save you having to make a speaker switcher. 94
lovepreet
Audio / Security / Video
Mar 20, 2017 08:04 AM
mad_ox1
Jul 25, 2015 12:27 PM
AJHondaAcc90
Oct 19, 2011 05:37 PM
GSR-EG-92
Jun 15, 2009 11:52 AM
blinger
Apr 9, 2007 11:07 PM
