rpm's drop low at idle and stall.
Old May 26, 2006 | 08:43 PM
Mr.Death's Avatar
Default rpm's drop low at idle and stall.
Has anyone had a problem with their rpms dropping low
at idle? Earrlier on today I had to keep my foot on the gas whever I came to a stop sign or the car would stall. Other than that the car ran well but would die at idle. I just had the car out and the problem had disappeared as the car started and idled like a champ. Any ideas as to what caused this low idle problem???
Thanks.
Old May 26, 2006 | 09:30 PM
themorphious's Avatar
Default Re: rpm's drop low at idle and stall. (Mr.Death)
umm same problem here too......but mine doesnt die...sometimes i feel like i gotta keep on the gas a bit or it's gonna stall........maybe i should just put a v-8 in my civic..lol, just kiddin......but on topic again......any ideas anyone?
Old May 26, 2006 | 11:19 PM
turbosnatch's Avatar
adjust the idle screw yet? or clean the iac?
Old May 26, 2006 | 11:42 PM
b_ron007's Avatar
do urself a fav, do a cylinder compression test.
Old May 27, 2006 | 10:17 AM
Mr.Death's Avatar
Default Re: (b_ron007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_ron007 &raquo;</TD></TR><TR><TD CLASS="quote">do urself a fav, do a cylinder compression test.</TD></TR></TABLE>
Alright I just did a compression test and had 185 across the board so comp looks perfect. Anyone else.
Old May 27, 2006 | 11:29 AM
wpgcivic's Avatar
ok what are you using for engine management? what you need to do is increase your rolling idle by maybe a couple hundred rpm and should be good to go
ic89
Oct 16, 2006 05:38 PM
tegman85
Mar 22, 2006 04:02 AM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
hodsintegra23
Mar 12, 2004 03:19 PM
