b16 running rich
Old May 26, 2006 | 03:22 PM
96hondab16a's Avatar
Default b16 running rich
Ok car is 96 with b16 P30, Dc header, Aem V2, MSD 8mm plugs. I just changed my spark NGK Iridium 6 but it hasnt been 30000 miles and torque 1/2 to 2/3 and now my gas just drops when steadying driving 70 on the high way and when changing gears does it to. Looking at the spark plug its grey, white on top and build up carb on the ring. When at idle it doesnt drop as much. The distributor is Mr Gasket clear so when looking at it spark at night i see a slight difference in the spark 3 cyl sparking really bright the other just a tiny bit you see spark but not dramatically . You think it could be off timing. Could it also casue me to run rich if its off timing??????? Anyone help me. Thanks
Old May 27, 2006 | 07:53 AM
Default Re: b16 running rich (96hondab16a)
Old May 27, 2006 | 10:54 AM
Walterronny's Avatar
im not sure but i think if you have a little bad the timing not rich or lean your A/F...
you refer to this?
if yes, it's normal.. you runing normal.. (a little rich of stock)
Old May 27, 2006 | 07:52 PM
i dont think its normal
Modified by 96hondab16a at 7:23 AM 5/28/2006
Old May 28, 2006 | 06:24 AM
Default Re: (96hondab16a)
anybody else???????
Old May 28, 2006 | 12:27 PM
JSPECSIR's Avatar
my b16a runs rich as **** if i drive about 80mph on i40, you can almost see the damn needle going down.......p30 also, but better with my chipped p28.
Old May 28, 2006 | 12:38 PM
Default Re: (5THGENSI)
doesnt help me at all????????????? anyone
Old May 29, 2006 | 01:10 PM
PBsTREETracer
Apr 12, 2008 06:39 PM
d16dcoe45
Nov 15, 2006 04:49 AM
96hondab16a
May 28, 2006 06:40 AM
megaman096
May 27, 2006 05:15 PM
joefuni
20
Aug 2, 2003 08:25 PM
