resistor box
Old May 26, 2006 | 06:34 AM
ef9ontime's Avatar
Default resistor box
I recently just did a b16 swap in my 91 civic si. I used the rywire obd1 conversion harness since i was ordering an obd1 motor. I am having a problem with the engine boging under accleration, and sometimes its really bad. I did a full tune up, checked everything-wiring, air in collant system, and everything seems fine. My question is that if I am running obd1, with obd1 injectors, do I need touse the stovk si resistor box? I am wondering if my injectors are not getting the corect voltage, thus making the car run like crap. hopefully someone knows..
Old May 26, 2006 | 06:57 AM
downest's Avatar
Default Re: resistor box (ef9ontime)
Regardless of what you are running for management, the injectors need to match the box. That is, OBD0 injectors need a box, OBD1 do not. You need to remove the resistor box.
Old May 26, 2006 | 06:59 AM
philkehn's Avatar
yea you dont need a box for obd1 because of the impendance or ohms or something like that
Old May 26, 2006 | 07:15 AM
ef9ontime's Avatar
Default Re: (philkehn)
alright thanks for the info.. now I just have to solder all 5 wires together, or do i solder the 4 red, and solder the black by itself>/. I just want to make sure before i go and do this. I dont need any fried wires to mess with,,
Old May 26, 2006 | 07:30 AM
Loserkidwac's Avatar
Default Re: (ef9ontime)
I'd say just get some OBD0 injectors...easier than rewiring and then if you do boost eventually yo can get some DSM 450s and already have the resistor box wired up for them
Old May 26, 2006 | 07:39 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9ontime &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks for the info.. now I just have to solder all 5 wires together, or do i solder the 4 red, and solder the black by itself&gt;/. I just want to make sure before i go and do this. I dont need any fried wires to mess with,,</TD></TR></TABLE>
um, did you get an engine conversion harness from rywire or just a jumper harness?
Old May 26, 2006 | 09:01 AM
ef9ontime's Avatar
Default Re: (temp)
I just bought a ecu conversion harness-just soldered them all together, no more bogging during accleration..
Old May 26, 2006 | 03:17 PM
ef9ontime's Avatar
nevermind, engine still bogs under accleration, and when I start off in first gear, I slip the clutch to engage, give it a little gas, and it bogs. So far I have changed cap, rotor, plugs, wires, fuel filter, pcv, removed resistor box, "map sensor knock", changed map sensor out for pm6(stock), checked timing, checked regulator, no misfires, no cels either.. If someone could help me figure this out, they wil be rewarded!- 91 civic si b16a-obd1-rywire ecu conversion harness.
Old May 27, 2006 | 11:41 AM
efyou's Avatar
tps? my b16 always had that "hesitation" usually from start up, i was told it was tps, i jus got rid of it for an ls tho lol.
Old May 28, 2006 | 01:23 PM
ef9ontime's Avatar
Default Re: (efyou)
well, today I just pulled my plugs out. 2 of em were black(looked normal,) and 2 of them were white.. I really dont know what to conclude from this... anyone got any ideas?
Hondamonster
Jul 29, 2007 08:42 PM
VTEC1n2nd
12
Jun 27, 2007 05:46 PM
mr. Grind
Aug 15, 2004 12:13 PM
kur0ryu
Apr 26, 2004 05:05 PM
JDMCivicEF9
19
Sep 6, 2003 11:00 AM
