eg hatch D16 swap running on 2 cylinders
Old May 26, 2006 | 05:12 AM
1gshow's Avatar
Default eg hatch D16 swap running on 2 cylinders
i swapped a d16z6 into my cx hatch and everything went pretty smoothly... besides a lil cranking problem all is well, except now that i got it started its only running on 2 cylinders... (cylinders 2 & 3) and 1 and 4 arent firing. so i did the basics. changed plugs wires. nothing. changed distributor cap and rotor. nothing, checked fuel, swapped injectors and clips to see if maybe it was a wiring issue or an injector issue, still only 2-3 fired. did a compression check 160 across the board. so it has to be the distributor right? thats the only thing i can think of. cuz its getting fuel spark on all 4 but it seems really weak on cylinders 1 and 4 thanks guys
crowscare
19
May 20, 2013 07:45 AM
driftguy2008
Mar 1, 2013 11:05 AM
SlowSOHC-T
Jul 8, 2010 01:41 PM
slammedEG1994
Dec 21, 2006 05:44 PM
civicspeed77
11
Jun 2, 2003 07:16 PM
