PROBLEMS HELP PLEASE so many days no hope
ok now this is the problem i have a 98 honda civic Hatch DX changed the head valves were done so i changed the head the gasket the intake gasket and the exhaust gasket all of a sudden their is ANTIFREEZE in my pistons so i take it out clean out all the antifreeze (Wasnt alot ok tad bit) and well put the gasket back on with HONDABOND put everything to specs 14lbs 36lbs and then 49lbs twice put the intake on and the Exhaust on but then the Antifreeze leaked from the INTAKE manifold where its connected to the head and the ENGINE keeps throwing out CELS (CHECK ENGINE) was wondering anyone PLEASE I MEAN ANYONE CAN U HELP ME WITH EXACT THINGS TO DO dont send me to a DIY juss tell me step by step also the timing supposedly is off we ******* did it 10 times took of the pully got it to top dead center then got the Cam to TDC or straight and put the belt on it and it sounds off any man its been 7 DAYS str8 to much hassle even the MECHANIcs ( i started the car before they even figured anything out but it dies) HELP!!!!!!!!!!!!!!!!!!!!
Re: PROBLEMS HELP PLEASE so many days no hope (Nicaraguense13)
Double check your timing marks.
make sure the hoses aren't the culprit of the leaks coming from the intake side.
I still don't understand why you would use hondabond on your headgasket.
Did you pull the codes?
Re: PROBLEMS HELP PLEASE so many days no hope (Slamaccord)
honda bond would i guess help uh with vaccum leaks?.. well check your intake manifold gasket.. if its not seated correctly its possible there is coolant seeping into the engine through the left most runner.... left= passenger lol.. anyway.. you might have a bad gasket.. or you might have some leftovers from a previous gasket on the manifold or head surface.. gotta get all that **** off homie..
for the codes..
do you know the code?
cant help you if u dont know the codes buddy
for the codes..
Re: PROBLEMS HELP PLEASE so many days no hope (w0ng_sta)
when i put the head gasket i dont need to put on gasket sealer?????? or do I?? on the intake manifold would i have to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 »</TD></TR><TR><TD CLASS="quote">when i put the head gasket i dont need to put on gasket sealer?????? or do I?? on the intake manifold would i have to?</TD></TR></TABLE>
Dios mio
I sure as hope that he is having a bad day and can't explain exactly what he is trying to.
Dios mio
I didnt put hondabond on the head gasket but on the INTAKE manifold i did it stopped the antifreeze problem but the car has rough idle and CHECK engine
https://honda-tech.com/zerothread/1171263
Go here and follow the steps to figure out what your CEL light means
elmejor
07-17-2009 03:45 PM
efyou
06-30-2006 04:09 PM
westspeed
07-12-2005 10:27 PM
