what the hell just happened?
Old May 25, 2006 | 08:29 PM
Kyoto now's Avatar
Default what the hell just happened?
I'm completely lost!! I was driving my hatchback when all of a sudden the tachometer started going crazy. I was going about 50 mph and my tach was bouncing all over the place from 1000RPM to 6000RPM. Then to make matters worse the car shut off on me! I waited a couple of minutes and I started it again. I drove a litttle bit and it started to backfire. Now it won't start at all. HELP PLEASE!
Old May 25, 2006 | 08:36 PM
Targa250R's Avatar
be professional
Default Re: what the hell just happened? (DA9 Purist)
Take off the distributor cap and see if the rotor is still firmly attached to the shaft.
Old May 25, 2006 | 08:42 PM
GdmLaz's Avatar
Default Re: what the hell just happened? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Take off the distributor cap and see if the rotor is still firmly attached to the shaft.</TD></TR></TABLE>
also check if the cap is not burn.. and if the shaft is intacked..
Kyoto now's Avatar
yeah, it is. in fact it was tuned up about 3 weeks ago. It was running absolutley perfect.
Old May 25, 2006 | 08:43 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it is. in fact it was tuned up about 3 weeks ago. It was running absolutley perfect.</TD></TR></TABLE>
Are you getting spark at the plugs?
Old May 25, 2006 | 08:44 PM
Kyoto now's Avatar
yes, definatley getting spark to all 4 cylinders
Old May 25, 2006 | 09:23 PM
eXcelonTypeR's Avatar
check your thermostat ground wire. 4 small gauge black wires crimped to a ring connector. That caused my hatch to have the buckin' tach, random loss of power, surging idle, etc.
Old May 25, 2006 | 09:27 PM
Paxil4x4's Avatar
Default Re: what the hell just happened? (eXcelonTypeR)
Ignitor went bad
Old May 25, 2006 | 09:41 PM
Frozen E's Avatar
H-T White Ops
Reaplace your/borrow somebody else's distributor. Ignitors are known to cause tach problems. And if your car is cutting off and now not starting, it's a real possibility that your ignitor took a crap on you.
Old May 26, 2006 | 09:02 AM
Kyoto now's Avatar
Default Re: what the hell just happened? (IslandSi)
ALL OF YOU WERE WRONG! The timng was off. My timing belt somehow jumped a few teeth.
Old May 26, 2006 | 09:13 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">ALL OF YOU WERE WRONG! The timng was off. My timing belt somehow jumped a few teeth.</TD></TR></TABLE>
you could say thanks for the help too. Glad you found your problem.
archuletac
11
Dec 12, 2007 07:46 AM
LukieLuc
Apr 4, 2007 06:35 PM
bleedblue94
Jan 5, 2006 06:40 AM
MaddMatt
Aug 1, 2005 05:10 AM
Calvinator
Nov 7, 2004 07:10 PM
