!!Need help with turbo oil return line!!
Old May 25, 2006 | 10:41 AM
ki11a8ee's Avatar
Default !!Need help with turbo oil return line!!
what fittings do you guys think I need for my return line. I was thinking of getting a 45 degree AN fitting right off the turbo drain flange and then another 45 degree fitting off the pan. thanks in advance
Old May 25, 2006 | 10:49 AM
StolenTeg's Avatar
Default Re: !!Need help with turbo oil return line!! (ki11a8ee)
a 45 degree would be a good idea and put it as high as possible, where your pointing the hose right now isnt going to cut it.
Old May 25, 2006 | 10:54 AM
B18C1CYA's Avatar
I would get one of these for the bottom of the turbo http://cgi.ebay.com/ebaymotors...ZWDVW it will gain you some hight on the pan
Old May 25, 2006 | 11:24 AM
ki11a8ee's Avatar
well i was thinking of taking off the straight fitting thats on the turbo drain flange and putting a 45 degree fitting on the flange instead.
Old May 25, 2006 | 12:55 PM
ki11a8ee's Avatar
Default Re: !!Need help with turbo oil return line!! (aallbbeerrtttttt)
thanks guys
Old May 25, 2006 | 01:06 PM
nfn15037's Avatar
It looks like you can just put a 90* fitting on there, weld a -10 weld-fitting on the pan and use about 2 inches of line to connect it all.
pjr710
Jan 14, 2010 03:28 PM
My JDM EJ8
Dec 30, 2008 06:57 PM
BigZeke5
Oct 16, 2008 06:20 AM
MADEINIRAQ
Jun 19, 2007 10:55 PM
JohnShaft
Aug 14, 2001 12:27 PM
