KILL SWITCH HELP!!!
Old May 25, 2006 | 08:31 AM
hondamoonchucks's Avatar
Default KILL SWITCH HELP!!!
hey guys.. yesterday iinstalled a fuel pump kill switch in my car... I flipped the switch both ways and the car still starts up fine either way...Why is it doing this??
I forgot to disconnect the negative part of the battery before i installed it but i took it off this morning and put it back on after 10 seconds... what could be wrong???
thanks guys....
Old May 25, 2006 | 08:37 AM
P1_Variable's Avatar
Default Re: KILL SWITCH HELP!!! (hondamoonchucks)
Maybe you conneced the swtich to the wire that shows fuel level instead of the power to the pump ?
Old May 25, 2006 | 08:40 AM
Relic1's Avatar
also keep in mind that the car will run for a few seconds with the pressure built up from the last time the pump ran...
JDM JUICE's Avatar
you probly connect the switch to a "non-important" wire like stated above
Old May 25, 2006 | 09:51 AM
pdiggitydogg's Avatar
http://www.hstuners.com/forums...24389
follow that how-to
Old May 25, 2006 | 11:02 AM
Default Re: (pdiggitydogg)
You should be able to see if the fuel cutoff switch is working just by turning the ignition to the on position and listening for the fuel pump to prime..
Old May 25, 2006 | 11:55 AM
PhatBoy5015's Avatar
Why do you need a kill switch?
Old May 25, 2006 | 12:13 PM
badcompany_2205's Avatar
Default Re: KILL SWITCH HELP!!! (aallbbeerrtttttt)
ya for sure....when you walk out to your car and its not there.....thats when your gonna hit yourself for not having all the protection you could have had. Like they say "its better to be safe then sorry"
Old May 25, 2006 | 12:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">
why do we need alarms?
why do we use autolocks?
why do we use clubs?
why do we lock our doors?
why do we park in the garage?
every bit helps to keep our car</TD></TR></TABLE>
I was asking because I really didn't know. I thought it had something to with racing or something. You know, like some kind of safety thing you had to do to race. I'm retarded.
Old May 25, 2006 | 01:19 PM
hybridej7's Avatar
Default Re: KILL SWITCH HELP!!! (PhatBoy5015)
might use this diagram for a fuel pump kill switch myself.....
Old May 25, 2006 | 05:42 PM
im pretty sure i got the right one... theres only one that has a yellow and green wire...
car seems to run fine in both positions...
anything to do with battery?
Old May 25, 2006 | 10:05 PM
bump
Old May 26, 2006 | 12:13 AM
fdavie's Avatar
Default Re: (hondamoonchucks)
No, it has nothing to do with the battery. You could have easily blown a fuse with the battery still hooked up, but that would make the pump never work, not always. The only thing that it could be was that you hooked up the switch wrong, either to the wrong wire or you didn't connect to the right contacts on the switch. Double-check your work.
integra_101
Jul 29, 2014 07:25 AM
Tapout383
Dec 1, 2009 05:09 PM
LS_VTECteggy
Oct 18, 2009 09:27 PM
dan_rehagen
44
Feb 3, 2006 07:18 AM
RUBZERK
Aug 18, 2004 08:45 AM
