ecu trivia
is a p72 ecu close to or the same as a p28 and can i use a p72 in my 92 civic with my d16z6 motor -crook: i can get 1 for cheap and im using a p05 ecu now would the p72 work
please help with the confusion and please lots of peeps put in their info
Nope you cannot use the P72..
the b series uses larger injectors. also that is for the GSR and you do not have secondary runners. Different fuel and igintion maps.
Go with a P28.. dont try to half *** things when it comes to the ECU
very tru thats not somethin that u wana mess with to much if u dont know what ur doin.... that little box controls basically ur whole fuel air ratio and many other functions that work with sensors and timing and lots of other ****. save ur money and buy a p28 *its for THAT engine* bad thing happen when u throw in different air/fuel ratio's than the car or ECU is set up for
