Help Before I shoot my self and the Car!!!
Ok so im ready to take my new ls turbo that was what i thought finally done out . And double cheched everything. every thing was good except that there was oil going to and from the turbo, but my brand new garrett t3/t4 compressor was not spinning very freely. ****, so i loosened it a little thinking that mabye i over tightened it when i clocked it, but nothing helped.
so, the FActs
The car has only started up and ran once for like less then 2 minute before this
Before on the car the compresssor spun freely by hand
The turbo is new
???? Im trippin cause this is my daily driver and i dont have much cash left + im moving from **** hole Michigan to Cali in a month and i have to have a running car!!
SOme one please help me before i shoot the car and my self!
so, the FActs
The turbo is new
this is my setup
B18b
Skunk2 intake manifold
B16 TB bored to Itr specs
DSM 450's
BMC race log manifold
turbo xs BOV
Turbonetics waste gate 38mm 6psi spring
Turboxs boost controller
Jonny Race car Frontmount intercooler with 2.25 inch intercooler piping
Gsr Tranny
Exedy Stage 1 organic clutch
8lb balanced flywheel
Obd2b-to-Obd1 conversion tuned on Uberdata
Garrett T3To4e COMPRESSOR SPECS:flow: 53 lbs/min 678cfm.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:.63 A/R HOUSINGSTAGE 3 WHEEL
All in a 99 si shell
B18b
DSM 450's
turbo xs BOV
Gsr Tranny
60 TRIM WHEEL
Well first confirm that the turbo is actually in fact receiving oil. Remove the turbo oil feed and put the end in a container to hold any oil that should come out. Then start the car.
ok i checked, oil is going to the turbo and it is also returning to the pan so there is full lubrication, but the compressor wheel will only spin half way when the car is off by hand and it spun alot more freely before i put it on , so im puzzled, would it be ok for me to take the housings off to see if somehow there is a restriction in the housings ??
yeah i did and i found the restriction it was a ******* plastic bag !!! I was nervous to take the cover off since this is my first turbo build and i didnt want to mess anything up, but im glad i did . ends up i got lucky that the hardened melted plastic bag didnt bend any of the fins
b18c1wes
Jan 5, 2005 01:48 AM
