is a VSS required for a non vtec car to run right?
Old May 24, 2006 | 11:42 AM
hb_guy's Avatar
Default is a VSS required for a non vtec car to run right?
has anyone here had problems with their cars while not having a vss? or driving with a broken one and throwing a code? thanks
Old May 24, 2006 | 11:53 AM
Driven's Avatar
Default Re: is a VSS required for a non vtec car to run right? (hb_guy)
nope.
Old May 24, 2006 | 06:10 PM
hb_guy's Avatar
Default Re: is a VSS required for a non vtec car to run right? (Driven)
u sure?
Old May 24, 2006 | 06:42 PM
SomeDude56's Avatar
no problems at all...except no speedometer but .. yea
Old May 24, 2006 | 06:52 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: is a VSS required for a non vtec car to run right? (SomeDude56)
When my car was stock,
It constantly threw code #17 for the speed sensor
even though the speedometer worked.
The car ran fine,so I just removed the check engine bulb..
I had to eventually replace the instrument cluster to make
the code go away.
Old May 24, 2006 | 06:55 PM
nelsmar's Avatar
been throwing CEL 17(VSS) for 2+ years now. no problem : )
i think myn is the cluster too just never installed the new one... there is a burnt trace on the back. i think i followed it to the speedo. cant remember
Old May 24, 2006 | 07:05 PM
88DXCRX's Avatar
Default Re: (nelsmar)
Speed pulser:
Connection at back of cluster; [the two phillips heads]
There are pics of the speedo cable connection at the tranmission
at the bottom of this thread:
https://honda-tech.com/zerothread?id=1325930
Old May 25, 2006 | 05:59 AM
hb_guy's Avatar
alright guys, thanks. now i know to look elsewhere for my prob
Old May 25, 2006 | 06:40 AM
crx_88_si's Avatar
lets not forget there are something that happen as a result of speed.
i know my cars alternator goes to 14v @ and above 45mph. back to 12.6v below 45mph.
Old May 25, 2006 | 08:18 AM
Loserkidwac's Avatar
Default Re: (crx_88_si)
When i did my swap it had a busted VSS and the car ripped still, no problems just no speedo and my cars milage never increase
Old May 25, 2006 | 10:45 AM
88DXCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">lets not forget there are something that happen as a result of speed.
i know my cars alternator goes to 14v @ and above 45mph. back to 12.6v below 45mph.</TD></TR></TABLE>
But that really has nothing to do with the vehicles speedometer/VSS..
The alternators output is being increased/decressed by the engines r.p.m.
Old May 25, 2006 | 02:14 PM
hb_guy's Avatar
Default Re: (88DXCRX)
i just wish i knew why i am losaing power in the top end. it feels like it wants to go but something is holding it back
Old May 25, 2006 | 02:41 PM
ludesrv's Avatar
What kind of engine?
Old May 25, 2006 | 08:23 PM
hb_guy's Avatar
Default Re: (ludesrv)
d16a6 block
d16y7 head
i/h
stock exhaust
si tranny
centerforce dual friction clutch
beatngyou27
26
Nov 8, 2013 06:59 AM
ma_rio44
11
Jul 15, 2007 09:24 AM
Mach69
Jun 3, 2005 06:50 PM
07
10
Apr 4, 2005 10:02 AM
GdmLaz
16
Dec 12, 2004 03:33 PM
